Want to Buy Want to Trade/Want to Buy
WTB: obd2a EX harness (96-98)
Old May 15, 2005 | 10:44 AM
Capt. Jimbo McSubipants's Avatar
Default WTB: obd2a EX harness (96-98)
let me know....i wanna try my vtec swap again in my hatch
i miss it...
Old May 17, 2005 | 10:49 AM
Default Re: WTB: obd2a EX harness (b16delteg)
^^^^^^ a few days later...
Old May 17, 2005 | 10:54 AM
klungemonger's Avatar
You could just modify your DX/CX harness for the VTEC wiring....alot cheaper than buying it. Only have to add 2 wires at the ECU & move 2 more to different pinouts. Add 1 ground wire on the engine side and add a couple connectors, boom thats it.
Old May 17, 2005 | 10:44 PM
Default Re: (klungemonger)
and um...about modifying my harness...i bought a Ls that came with a supposive non hacked DX harness....its to complicated and this guy is an idiot...so i'm just gonna buy the easy and simple EX harness...if someone can cut me a deal
Old May 18, 2005 | 06:10 AM
You still have to do at least one mod on an EX harness unless you use an OBD1 ecu conversion. SOHC harnesses use a 3-wire crank flux sensor/plug, the B-series only have a 2-wire so you need to get a 2-wire plug and swap that in if you are using an OBD2 LS ecu.
If you are just putting a stock LS in the only other mod besides the crank sensor is the IACV needs to be changed from 3-wire to 2-wire plug. If you have a DX model Civic and use an EX harness, all the wiring & plug for the secondary O2 sensor will be missing from your vehicle. Again if you use OBD1 ecu this is not a problem, but if you are staying OBD2 you can just relocate the wires/plug for the secondary O2 sensor or just put an extension on it.
Old May 18, 2005 | 06:37 AM
OVA's Avatar
OVA
I have 97 integra LS Vtec DOHC 5sp tranny harness fro sale 80 you pay the shipping Please email @ Frankoporsche2000@Yahoo.com
Old May 18, 2005 | 06:42 AM
Integra engine harnesses do not work in 96-up Civics, at all.
Joacnel
Aug 25, 2012 03:53 AM
h22accord101
Dec 11, 2010 01:24 PM
Slick2126
Apr 2, 2006 05:03 AM
FrankieFive
Jul 12, 2005 12:57 PM
96hatch96
Jul 28, 2003 08:13 PM
