cluster Dead HELP ANYONE ASAP
Old May 15, 2005 | 01:18 AM
hachboy557's Avatar
Default cluster Dead HELP ANYONE ASAP
OK so i'm driving and I bottomed out big time-nothing is hurt but my cluster on the dash went dead...Right after this happen I tryed to use my turn singles and nothing so i went to put on my 4 ways,-pop went the fuse so i replaced the fuse for the 4 ways thinking it might have something to do with the turn singles....still no turn singles, no speed meter...no temp. gage.....no gas gage...NOTHING IS WORKING and I have tryed just about everything....checked most of the wires and fuses....
A lil about my car I have a 95 hach DX 1.5.....With a D16 ecu and just about everything bolt on- on the motor intake ect....
WHAT COULD IT BE?
Give me some info Please.......!!
Old May 15, 2005 | 02:12 AM
hachboy557's Avatar
Default Re: cluster Dead HELP ANYONE ASAP (hachboy557)
Someone? ANYONE?
Old May 15, 2005 | 08:46 AM
oddy's Avatar
bump.
Old May 15, 2005 | 08:56 AM
Luserkid's Avatar
Default Re: cluster Dead HELP ANYONE ASAP (oddy)
check all your fuses.
Old May 15, 2005 | 09:00 AM
oddy's Avatar
Default Re: cluster Dead HELP ANYONE ASAP (Luserkid)
he did already... and I searched through all 5 pages of info I could find and there werea few posts similar to this and none of them actually had an answer, they all had the same exact issues to. 4 way hazards work, but no individual turns. Hi beam light still comes on, but everything else is dead.
Old May 15, 2005 | 01:52 PM
oddy's Avatar
up again..
Old May 15, 2005 | 06:39 PM
hachboy557's Avatar
Someone gotta know something i didnt try......
I checked all fuses their all good....ones inside and under the hood.....
I checked all the plugs under the hood everything is there and all good......
Its a bullcrap problem.....but if i take it to a honda dealer I know it'll be like 200 bucks to fix bc its gotta b something dumb that i am missing.......
Old May 15, 2005 | 07:14 PM
.Kevin.'s Avatar
ill give u a free bump since i cant help
Old May 16, 2005 | 08:39 AM
oddy's Avatar
Default Re: cluster Dead HELP ANYONE ASAP (Slow_CvC99)
and somebody out there has to know what's up
Old May 17, 2005 | 10:01 AM
hachboy557's Avatar
Is it a computer problem.......
SOME ONE
Old May 17, 2005 | 11:41 AM
Relic1's Avatar
there is no common fuse for all those things but it may be G401, which is becoming a semi-regular problem on EGs.
It's a bundle of ground wires under the dash just to the left of the fuse box.
It's ground for everyone of the circuits you mentioned. All though it does high beams and hazards also, but it may be through a different connection to the actual grounding point so check it out.
it's pulled out here to show the actual connection in detail on the lower left, follow the connecting line to where it is in the car.
wiggle/push/pull/etc the wires and see if anything starts working. if it does you've found the problem.
if you have a multi-meter, some electrical knowledge and feel like following directions I can help you troubleshoot this and help everyone with this problem.
Old May 17, 2005 | 11:51 AM
ironlung78's Avatar
Default Re: cluster Dead HELP ANYONE ASAP (Relic1)
i'm not sure but is that 0bdII??? with D16 ecu?
i've seen where the 2ndary 02 sensor or the wire itself gets destroyed or ripped out when bottoming out, causing very similar problems. if its 0bdII jack it up and check it out. if not then free bump
Old May 17, 2005 | 12:01 PM
Relic1's Avatar
Default Re: cluster Dead HELP ANYONE ASAP (sidesi)
'95 is OBD1
Old May 17, 2005 | 12:05 PM
ironlung78's Avatar
i know 95 is 0bd1 but if you read what he wrote and i wrote isn't a D16 ecu obd2?
Old May 17, 2005 | 02:02 PM
Relic1's Avatar
I guess I assumed he meant an OBD1 D16 (see D16Z6)
since converting an OBD1 car to OBD2 would be a PITA.
but yah, I assumed.
hachboy557 - which D16 ECU?????
Old Oct 3, 2007 | 08:40 PM
I_eat_Rice's Avatar
Default Re: (Relic1)
did anyone ever find an answer to this problem my corner light came out after a small wreck I had and now my speedo, tach, temp, fuel, blinkers dont work. although my running corner lights do work.
Old Oct 3, 2007 | 10:18 PM
Z3120's Avatar
Default Re: (I_eat_Rice)
Check out the wiring list in the link below. With a voltmeter check to see if you have power and ground @ the right pins.
https://honda-tech.com/zerothread?id=1053318
Old Oct 4, 2007 | 06:48 AM
slacks's Avatar
Default Re: (Z3120)
yeah use a volt meter because it sounds like you might have demolished a ground somewhere
if so, it's an easy fix once you find out where. i hope that helps any
ef hatchDUDE
Dec 2, 2012 06:43 AM
boostfever
May 11, 2009 06:52 AM
honda_conversion
Jun 22, 2007 11:31 PM
unknown0001
Aug 9, 2006 02:03 PM
juanb
14
Dec 17, 2003 08:21 PM
