probably talked about to death but....
Old Feb 4, 2002 | 09:53 PM
Louie B.'s Avatar
Default probably talked about to death but....
I'm sure this topic's been up before, but I can't find it in any of my searches:
I'm planning to buy a "88-91 (B16A Sir 1) Complete Change Over" from http://www.hondamotorsonline.com and I have a couple of questions for people who have purchaced from them before.
1. They list that it comes with axles and half-shaft. Will these work on the USDM 91 civic std hb (with the si hubs and knuckles) or do i still need to get some 90-93 teg axles?
2. I think I know the answer to this, but just to be sure, they list that it comes with mounts. I still need aftermarket swap mounts, right?
3. same as #2 only for shift linkage.
4. They list engine harness. Is it enough of a harness to swap out my STD harness to MPFI?
and finally 5. I've seen elswhere on the board that the factory LSD tranny is not a good idea and that I'd be better off getting a non LSD and putting an aftermarket one on. any opinions?
Just Ignore this post if you're tired of these questions.
[Modified by thumpu77, 6:55 AM 2/5/2002]
[Modified by thumpu77, 6:56 AM 2/5/2002]
Old Feb 5, 2002 | 03:03 AM
keithv's Avatar
Default Re: probably talked about to death but.... (thumpu77)
when you do a search, make sure to click "post bodies" under the "search in" portion. the default place to search is topic titles and usually that doesnt return and info....
jarol220
May 31, 2011 10:58 PM
88civhatch
10
Jul 11, 2005 02:13 PM
BigPlansNoMoney
Mar 2, 2005 05:32 AM
p3s7
Oct 15, 2003 10:45 AM
