Cluster doesnt light on after installing a headunit
Old May 14, 2005 | 05:15 PM
dungsta's Avatar
Default Cluster doesnt light on after installing a headunit
I have a 97 itr and i recently had a new head unit put in and evey since the the gauge cluster's back light wont come on .. i kno the light isnt messed up because when i turn the alarm on and off it still blinks... i've checked the fuses seeem like nuttin is blown..
can someone help me out thanks.. i cant drive at night!!
thanks..
Old May 14, 2005 | 05:17 PM
DeadVet's Avatar
Default Re: Cluster doesnt light on after installing a headunit (dungsta)
did you install it yourself? Is there a wire for illumination? If so make sure its not grounding out.
Old May 14, 2005 | 05:24 PM
dungsta's Avatar
Default Re: Cluster doesnt light on after installing a headunit (1TurboHatch)
yeah i installed it myself i think some wire was touching and made the cluster shut off...
which wire is the illumination?
Old May 14, 2005 | 05:30 PM
DeadVet's Avatar
should be orange or yellow. Im pretty sure its orange. Check the fuses and make sure its not blown because if it grounds out it will blow a fuse.
Old May 14, 2005 | 07:10 PM
dungsta's Avatar
i think thats what caused it... now my lights arent working anymore..
i dont think any fuses were blown cus i checked it any help on that?
Old May 14, 2005 | 10:25 PM
PrettyLude's Avatar
checked the backup and interior lights fuse? i did that one time too, i grounded something for the radio out, and i had no instrument cluster lights or tailights
Old May 15, 2005 | 01:39 PM
dungsta's Avatar
Default Re: (PrettyLude)
is taht how you fix yours?
Old May 15, 2005 | 03:14 PM
e2000's Avatar
its a fuse under the dash driver's side...it happened 2 me..jsut find the blown one
Old May 16, 2005 | 01:57 PM
dungsta's Avatar
Default Re: (e2000)
thanks it works noww
ElectronMan
Apr 25, 2013 04:09 PM
uptownx24x
Aug 11, 2011 07:11 PM
bresk8r87
Oct 17, 2007 07:47 AM
Streetdreams022
Jan 8, 2005 08:20 AM
