clicking or "ping pong" sound coming from right front wheel under accel/de-accel
Old May 14, 2005 | 02:05 PM
uncleben's Avatar
Default clicking or "ping pong" sound coming from right front wheel under accel/de-accel
<FONT SIZE="2">edit: Back from the dead! See the last page for the solution, woo hoo! </FONT>
As referenced in these old posts (some or all of which may be the same thing as me)
https://honda-tech.com/zerothread?id=510335
https://honda-tech.com/zerothread?id=547543
https://honda-tech.com/zerothread?id=659823
I am hearing this clicking sound on the driver side front. It sounds like it is coming from the suspension/wheel area. I did not notice this sound before installing the Tein's a few months ago and have just now gotten around to trying to figure out what it is. I took off the front right coil-over and made sure there weren't any rocks or crud stuck anywhere, I cleaned it all up, and I retorqued everything when I put it back together. I had someone else get in my car and just lightly drive forward and back while I stood next to it and it is definitely coming from behind the wheel. It's driving me insane. The exam same sound was heard on my friend's old Civic Si after we install some Eibach springs years ago. Never figured out what it was on his either.
My car has 50K miles and I doubt I have any bearings/axle problems, but I suppose I can't completely rule that out. Just odd it started happening after the Tein's went on.
Anyone have any clues? Jond, did you ever figure out your problem?
Modified by uncleben at 7:24 PM 5/18/2006
Old May 16, 2005 | 04:32 AM
uncleben's Avatar
Default Re: clicking or "ping pong" sound coming from right front wheel under accel/de-accel (uncleben)
Anyone? Buuuuuuueller?
Old May 16, 2005 | 04:46 AM
punkracer's Avatar
is it vibrating or pulling to either side?
Old May 16, 2005 | 02:42 PM
Dan in Japan's Avatar
Default Re: clicking or "ping pong" sound coming from right front wheel under accel/de-accel (punkracer)
Not sure if its the same noise I was hearing yesterday but.... One of the two nuts that are used to secure the valve stem on my wheel came off and was trapped inside the tire, tingging like crazy at low speed. You may try and take your tire off and shake it, maybe its the same problem. Hope it helps..... I can't stand a rattle either.
Old May 16, 2005 | 05:23 PM
Louie's Avatar
What would Chente do?
Default Re: clicking or "ping pong" sound coming from right front wheel under accel/de-accel (Dan in Japan)
sounds like your axle is bad (inner joint) if ya ask me. why not swap the susp. back how it was and go from there? at least you'll know...
Old May 16, 2005 | 05:59 PM
davidnyc's Avatar
Not sure if it is in the links in your posts. What fixed my "click" was simply loosening the axle bolts and then retightening them to the proper torque (I think it is 135lbft). Better yet, use new axle nuts also.
Old Jul 1, 2005 | 08:58 AM
p nut's Avatar
Default Re: clicking or "ping pong" sound coming from right front wheel under accel/de-accel (davidnyc)
Any updates on this? That clicking is driving me insane!
I'm on stock suspension. I only hear it on first gear take-offs (not launches) and now it's moved on to second gear shifts, also. It's coming from the front driver's side wheel area.
Old Jul 1, 2005 | 09:32 AM
Bbasso's Avatar
Default Re: clicking or "ping pong" sound coming from right front wheel under accel/de-accel (P Nut)
do you have a helms book? if so get under the caR and start checking the tq on the bolts and nuts.
Old Jul 1, 2005 | 09:49 AM
bender's Avatar
Same sound here, for about 3 weeks now. A metal-on-metal sounding click or ping, mostly whe I'm letting out the clutch in first or second, sometimes third. And sometimes when pushing in the clutch also. But only under load.
I thought it was clutch related, so I lubed the slave cylinder as mentioned in a bunch of threads about "clutch click", but no help.
I also recently installed Konis (3 months ago) so I thought that could be it, but I can't find anything loose or out of place around the shocks.
I'll check axle nut and drive shaft bearings. Any other ideas?
Old Jul 1, 2005 | 10:30 AM
mstewar's Avatar
Default Re: clicking or "ping pong" sound coming from right front wheel under accel/de-accel (bender)
mine started doing it after swapping LCAs.. same noise most others are describing and only on the driver's side.. I suspect I mis-torqued something and will be checking it out this weekend..
Old Jul 1, 2005 | 11:16 AM
Eva01's Avatar
My car has made the same clicking/popping noise ever since I purchsed the car with 20K on the odometer. At first, I thought it was my hytech header hitting my flywheel brace. So I addressed that issue and the noise continued.
Then I though maybe it was my clutch making the noise. However, after replacing the clutch the clicking noise continued....
Now I'm at 65K and think I have isolated the noise somewhere around the front ds. I'm gonna try and tighten my axel nut and see if that solves the problem...
Old Jul 1, 2005 | 11:18 AM
.RJ's Avatar
.RJ
Default Re: (Eva01)
Axle nuts. Replace, overtorque (i'm not kidding), and stake them down good.
Old Jul 1, 2005 | 11:44 AM
p nut's Avatar
What are torque specs for the axle nuts? 135lb/ft?
*edit: nevermind. It's 134 lb/ft.
Who needs helms when you've got "search"
Old Jul 1, 2005 | 11:46 AM
ITRbroham's Avatar
shit post warrior
Default Re: (.RJ)
I had this problem right before my '98 was stolen. I would hear a clunking noise coming from the left front of my ITR during accel. and decel. I took to the local Acura dealer and they replaced both the left and right axles plus the inner one. Luckily, I was cool with the service writer and he warrantied it for me for an under-the-table-fee.
Old Jul 1, 2005 | 01:16 PM
.RJ's Avatar
.RJ
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">What are torque specs for the axle nuts?</TD></TR></TABLE>
Whatever my impact gun puts out
Old Jul 1, 2005 | 01:33 PM
p nut's Avatar
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Whatever my impact gun puts out </TD></TR></TABLE>
So you just tightened the f@@k out of them? Maybe I'll give that a shot...
Old Jul 1, 2005 | 01:44 PM
.RJ's Avatar
.RJ
Default Re: (P Nut)
Yes, I put new ones on though
Old Jul 2, 2005 | 06:45 PM
vecspeed12's Avatar
Default Re: (.RJ)
i have the same problem.. i thought my motor mounts were loose.. i still cant figure it out either.
Old Jul 31, 2005 | 08:40 PM
japspec's Avatar
Default Re: (vecspeed12)
Damn I'm getting the same sound like a click click sound when the car moves or jerks. Its coming from the driverside front wheel and you can hear it outside the car man its annoying.
Old Jul 31, 2005 | 09:28 PM
97 TYPE-R 312's Avatar
Default Re: (japspec)
This is a common issue that I am having too. Stock suspension with 80K+ miles.
-Victor
Old Aug 1, 2005 | 10:59 AM
citrus3000psi's Avatar
i have the problem as well from what I can i have figured out its one of these things:
Castle nuts not tighened - tighten nuts
Cv joint going out - replace axle
Axle nut loose - tighen axle nut
Support axle bearing is loose - replace bearing or entire part/assembly
Thast all I have found out. I've done everything that doesn't cost money... and nothing has fixed it.
Old Aug 1, 2005 | 12:41 PM
BRICKHEAD's Avatar
Default Re: (citrus3000psi)
Lay on the ground and look on the back side of your rim. If there is any kind of greese on there than your outer axel boot ripped and it is an easy fix. Two options are replace axel and turn in old one for a core charge or replace outer boot if you are mechanically inclined to do so this route could save you a few bucks. Good luck.
Old Aug 1, 2005 | 01:27 PM
japspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">i have the problem as well from what I can i have figured out its one of these things:
axle is fine so its not that. Something is loose cause it just clicks when the car makes a slight movement and makes a click click sound like a switch.
Old Aug 1, 2005 | 05:56 PM
BRICKHEAD's Avatar
Check the nuts on the outer tie rods that are connected to the steering rack?
Old Aug 1, 2005 | 06:12 PM
japspec's Avatar
Default Re: (BRICKHEAD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BRICKHEAD &raquo;</TD></TR><TR><TD CLASS="quote">Check the nuts on the outer tie rods that are connected to the steering rack?</TD></TR></TABLE>
Yep you hit on the head outer tierod boot was ripped.
