is it ok to boost a stock motor
Old May 13, 2005 | 07:10 PM
89civicsiB18B's Avatar
Default is it ok to boost a stock motor
...my internals are stock.....would it be ok to run like 8-10psi of boost......thanks
Old May 13, 2005 | 07:12 PM
blackoutcivic's Avatar
Default Re: is it ok to boost a stock motor (89civicsiB18B)
i would run a little less boost (6 or 7), and bossibly use a inlinepro headgasket to lower the compression some depending on your current cr.
TUNING w/ hondata, uberdata, etc is critical!
dthrone's Avatar
what is your set-up!?! Kit EMS ect.
Old May 13, 2005 | 07:47 PM
hondaeg8's Avatar
i ran my bone stock ls motor on 8 and 10lbs of boost for 7-8 months with no problems. that was untuned also on a greddy kit.
Old May 13, 2005 | 08:19 PM
s2kdre's Avatar
Default Re: is it ok to boost a stock motor (hondaeg8)
oh geez, you can run up to 15psi with good ems.
Old May 13, 2005 | 08:34 PM
TurboGoKart's Avatar
Default Re: is it ok to boost a stock motor (jdmhonda)
Yeah, 8-10 is all gravy provided that you have a good tune. I've been running my Z6 at 10 psi for the past 25k miles and raping it hard.
Old May 13, 2005 | 09:07 PM
97hb's Avatar
14lbs daily
Old May 14, 2005 | 12:08 AM
Ls1 FD3s's Avatar
Default Re: is it ok to boost a stock motor (97hb)
10psi daily.
100% stock block champ.
Hp kills engines, not PSI.
Old May 14, 2005 | 12:16 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: is it ok to boost a stock motor (blackoutcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackoutcivic &raquo;</TD></TR><TR><TD CLASS="quote">i would run a little less boost (6 or 7)</TD></TR></TABLE>
single digit psi is for pussies.
11 psi daily driven right here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls1 FD3s &raquo;</TD></TR><TR><TD CLASS="quote">10psi daily.
Hp kills engines, not PSI.</TD></TR></TABLE>
word!
Old May 14, 2005 | 07:56 AM
blackeg's Avatar
Default Re: is it ok to boost a stock motor (Ls1 FD3s)
definate word
on the ls motor, you are golden to run 8 psi wiht it stock.
im running 7-8 psi for now, my motor has over 200k miles on it, and its been doing good for the 2000 mile i put on it in the past month. oh yea, i dont drive it without seeing full boost either
cabelaguy@msn.com
Sep 12, 2007 06:29 AM
PphamEK
May 27, 2006 12:05 PM
markvqwerty
Aug 27, 2004 03:59 PM
Turbo-Si
Mar 6, 2004 10:14 PM
Wrath of VTEC
Sep 15, 2003 06:58 PM
