OBD-1 Conversion Harness
Old May 13, 2005 | 04:35 PM
BLUE EH3's Avatar
Help we my pennies
Default OBD-1 Conversion Harness
why do people with a OBD2 car/motor get a "OBD-1 Conversion Harness"
Modified by BLUE EH3 at 8:50 PM 5/13/2005
Old May 13, 2005 | 04:45 PM
Deemeetree's Avatar
Electrician
To place an older, OBD-1 engine into a newer, OBD-2 vehicle. Makes it easier to run the ECU and all the proper harnesses without doing a hack job and installing Algerian Engineering.
Old May 13, 2005 | 05:09 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (Dimitri_EG8)
bump
Old May 13, 2005 | 05:29 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (BLUE EH3)
so your obd2 wires can plug into an obd1 ecu
Old May 13, 2005 | 05:32 PM
specv5150's Avatar
Default Re: (CoupeVtec2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoupeVtec2k &raquo;</TD></TR><TR><TD CLASS="quote">so your obd2 wires can plug into an obd1 ecu</TD></TR></TABLE>
Basically OBD2 ECU's are "unchippable" for lack of a better word. You get a OBD1 conversion harness to run a P28 or other OBD1 ECU to give you control
Old May 13, 2005 | 05:46 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (specv5150)
or say u have an obd1 b16, if u put that in an obd2 car u can use the 99-00si ecu n ur car will still read as n obd2 engine, n u may even be able to pass inspection
Old May 13, 2005 | 05:55 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: OBD-1 Conversion Harness (BLUE EH3)
u might wana take ur zip code from below ur avatar, mfers dont play in jerz
Old May 13, 2005 | 07:09 PM
chile's Avatar
in the same boat here...would the conversion affect smogging it in a year?
Old May 13, 2005 | 08:19 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (chile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chile &raquo;</TD></TR><TR><TD CLASS="quote">in the same boat here...would the conversion affect smogging it in a year?</TD></TR></TABLE>
putting an older engine in a newer car will cause u to fail
if putting an older engine into a new car jus get the ecu for the gen of your car instead of converting back for example:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoupeVtec2k &raquo;</TD></TR><TR><TD CLASS="quote">or say u have an obd1 b16, if u put that in an obd2 car u can use the 99-00si ecu n ur car will still read as n obd2 engine, n u may even be able to pass inspection </TD></TR></TABLE>
NOman0608
Jul 26, 2007 10:28 AM
Civic98KH
Mar 11, 2007 09:21 PM
shawnc21
Jan 9, 2003 11:21 AM
Gmedalion
Jul 10, 2002 07:56 AM
