fuel gauge not working...
Old May 12, 2005 | 10:41 PM
gogRac213's Avatar
Default fuel gauge not working...
i just got si cluster and the fuel gauge is not working...it is just pointing to full. Does any1 have any clue why it isnt working??
if i put my stock cluster back on, the fuel gauge is still working.
Old May 13, 2005 | 05:47 PM
gogRac213's Avatar
Default Re: fuel gauge not working... (gogRac213)
no one knows this stuff???
Old May 13, 2005 | 05:52 PM
hondapwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gogRac213 &raquo;</TD></TR><TR><TD CLASS="quote">no one knows this stuff??? </TD></TR></TABLE>
Does the needle on the Si cluster move at all, or is it stuck at full even when it's out of the car?
Old May 15, 2005 | 09:06 PM
gogRac213's Avatar
Default Re: fuel gauge not working... (hondapwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapwr &raquo;</TD></TR><TR><TD CLASS="quote">
Does the needle on the Si cluster move at all, or is it stuck at full even when it's out of the car?</TD></TR></TABLE>
yea...its stuck even when it full..
Old May 15, 2005 | 09:09 PM
EK k kay's Avatar
I had that problem. Did you mess around with the needles?
Old May 15, 2005 | 09:27 PM
gogRac213's Avatar
Default Re: fuel gauge not working... (chowmien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien &raquo;</TD></TR><TR><TD CLASS="quote">I had that problem. Did you mess around with the needles?</TD></TR></TABLE>
nah..its gonna mess up with the calibration if i do that...
but i did mess with the screws in the back..and found out that..if they are loose, the gauges wont work.. so, im guessin that theyr the ground or something.. but i still cant figure out y is the fuel gauge keeps on pointin to full...
Old May 15, 2005 | 09:30 PM
EK k kay's Avatar
If you just bought it then the previous owner probably messed it up.
Old May 15, 2005 | 09:54 PM
gogRac213's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien &raquo;</TD></TR><TR><TD CLASS="quote">If you just bought it then the previous owner probably messed it up.</TD></TR></TABLE>
it was workin..then i changed the bulb cuz it was out.. then when i installed the cluster again..it wasnt working. i replaced it with the same bulb too..
Old May 19, 2005 | 10:50 PM
gogRac213's Avatar
no body knows?
OneSloEk9
Dec 19, 2010 12:22 PM
anfgermany
Mar 27, 2007 10:06 AM
gsrHB
Sep 5, 2005 11:34 AM
faded
12
Aug 29, 2005 01:05 PM
MaskedAP1
Nov 6, 2004 05:57 PM
