gauge cluster problem
Old Nov 5, 2004 | 12:17 PM
MaskedAP1's Avatar
Default gauge cluster problem
ok my old fuel gauge is not working, so i get a new one. i filed up the gas, and put the needle to 'F' then i start up the car, but fuel needle go all the way down to E,like below E! any idea why is that?
Old Nov 5, 2004 | 12:23 PM
tegz up hoez down's Avatar
Default Re: gauge cluster problem (MaskedDC4)
why not leave it on e and let the gauge move on its own
Old Nov 5, 2004 | 01:17 PM
BlueIntegraBoy's Avatar
I wonder if 94-97 and 98-01 cluster issues has an effect to this. I doubt it since it's all in the green film. Did you make sure those screws that hold it in are screwed on well?
Old Nov 5, 2004 | 02:18 PM
MaskedAP1's Avatar
Default Re: gauge cluster problem (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">I wonder if 94-97 and 98-01 cluster issues has an effect to this. I doubt it since it's all in the green film. Did you make sure those screws that hold it in are screwed on well?</TD></TR></TABLE>
i think the screws r tight enough.. mine is 99ls , and i got a 94-97 gsr one....but other things work well..
Old Nov 5, 2004 | 02:40 PM
MaskedAP1's Avatar
Old Nov 5, 2004 | 03:16 PM
SYTFU Tommy.'s Avatar
u need to switch ur green sheet since u said the gsr cluster is 94-97 and u got a 98+
Old Nov 5, 2004 | 03:18 PM
MaskedAP1's Avatar
Default Re: gauge cluster problem (tngay)
but what it to do with the fuel gauge? like i said others work well
Old Nov 5, 2004 | 03:53 PM
MaskedAP1's Avatar
anyone
Old Nov 5, 2004 | 04:00 PM
SHystrdyGSRtdy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaskedDC4 &raquo;</TD></TR><TR><TD CLASS="quote">
i think the screws r tight enough.. mine is 99ls , and i got a 94-97 gsr one....but other things work well..</TD></TR></TABLE>
there's your problem... you need a 98+ cluster
you change the green film from you 99 cluster into your 94-97 cluster... you'll be gold.... i just did this 3 min ago
Old Nov 5, 2004 | 04:02 PM
MaskedAP1's Avatar
Default Re: gauge cluster problem (SHystrdyGSRtdy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">
you change the green film from you 99 cluster into your 94-97 cluster... you'll be gold.... i just did this 3 min ago</TD></TR></TABLE>
u mean if i change the green film, my fuel gauge should work then?
Old Nov 5, 2004 | 04:11 PM
well... since your car is a 99.... you need a 98+ cluster or at least a 98+ green film in the back of your 94-97 cluster
Old Nov 5, 2004 | 04:15 PM
MaskedAP1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">well... since your car is a 99.... you need a 98+ cluster or at least a 98+ green film in the back of your 94-97 cluster</TD></TR></TABLE>
like i said every other things r work well..my PROBLEM is the fuel gauge.. i took the cluster out, replace the fuel guage, filed up gas, and set the fuel needle pointing F, then start up the car.. the needle was going all the way down to E.
i wondering why
Old Nov 5, 2004 | 04:29 PM
Built B18ABorC's Avatar
Did you check your fuel pump? There is a lever on the pump which tells the needle if it full or not. As the lever inside the fuel pump goes down so does the needle on the cluster. Check your connections on the pump. Its either a bad pump lever or needs an adjustment, or you have a damaged wire/loose connection.
Old Nov 5, 2004 | 04:33 PM
MaskedAP1's Avatar
Default Re: gauge cluster problem (Built B18ABorC)
where to check the fuel pump?
Old Nov 5, 2004 | 06:14 PM
Under the rear seat cushion
Old Nov 5, 2004 | 06:33 PM
W.O.P.'s Avatar
i have this problem too but mine is staying on "f"
Old Nov 5, 2004 | 07:35 PM
MaskedAP1's Avatar
Default Re: gauge cluster problem (chirpin_3rd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chirpin_3rd &raquo;</TD></TR><TR><TD CLASS="quote">i have this problem too but mine is staying on "f"</TD></TR></TABLE>
so how is this now?
Old Nov 5, 2004 | 08:57 PM
first off... which cluster do you have? 94-95 or 96-97? 98+? i'm not sure if there's a difference between a 94-95 and 96-97 cluster but there is a difference for sure between the 96 and the 99... i have a 99 gsr.. i put in a 96 type r cluster in... fuel does not work because of the older cluster... you have to change the green film to the year of your car....
Old Nov 5, 2004 | 09:02 PM
b-power's Avatar
in the obd1(94-95) cars, the obd2(96and up), gas gauge on the cluster does not work
Old Nov 5, 2004 | 09:12 PM
MaskedAP1's Avatar
Default Re: gauge cluster problem (b-power)
im not sure which year(94-97) gsr cluster it is. but from this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b-power &raquo;</TD></TR><TR><TD CLASS="quote">in the obd1(94-95) cars, the obd2(96and up), gas gauge on the cluster does not work</TD></TR></TABLE>
mine should be obd1 which is 94-95
Old Nov 5, 2004 | 09:13 PM
MaskedAP1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">first off... which cluster do you have? 94-95 or 96-97? 98+? i'm not sure if there's a difference between a 94-95 and 96-97 cluster but there is a difference for sure between the 96 and the 99... i have a 99 gsr.. i put in a 96 type r cluster in... fuel does not work because of the older cluster... you have to change the green film to the year of your car....</TD></TR></TABLE>s
i will try that, thanx
hope thats the problem
Old Nov 5, 2004 | 09:34 PM
even more specifically, my 96 itr cluster(fuel gauge) (which is obd2) doesn't work on my 99 gsr (obd2 also)
Old Nov 5, 2004 | 09:36 PM
MaskedAP1's Avatar
i should ask this earier.. i thought my fuel gauge is not working, and i bought one too... now seems like not the fuel gauge..damn
Old Nov 5, 2004 | 11:45 PM
Did the film swapping work?
Old Nov 6, 2004 | 12:42 AM
gsr_to_the_MAX's Avatar
anyone know how much the green sheet/film cost? my gas gauge is broken too. i got a scratch on the green sheet and now my gauge is always past full
