need help picking a motor
Old May 12, 2005 | 05:55 PM
bleedblue94's Avatar
Default need help picking a motor
ok heres the story....i have a 98 hatch. ive had a b16 in it, and presently have a b16 block with gsr head and itr tranny. its a great motor, but i want more torque and am willing to sacrifice top end speed and revs for it. this is for my daily driven car so i need reliability, and i also have added weight in the rear from a competition stereo. im planning on staying all motor with it. im debating right now between a b18b or b20z. im leaning more to the b20z bc of the obvious power benifits. i plan on keeping my itr tranny either way and using it on the new motor. id like your guys input on this.....its not that i havent search....ive done allot of that, id just like some present day opinions from you guys as well.
tia
Old May 12, 2005 | 06:30 PM
also i dont regularly beat on my motors...just have fun like everyone ......
Old May 12, 2005 | 06:33 PM
Turbo_y8's Avatar
Default Re: need help picking a motor (bleedblue94)
doa b20 bore and sleeve stroker kit and then youll have all the torque you want or just do h22
Old May 12, 2005 | 06:34 PM
Bimmerman's Avatar
Default Re: (bleedblue94)
add a JRSC it adds lots of bottom end power and torque, it easy to install and maintane and is reliable. Plus you can get a used kit a lot cheaper than trying to swap out for another engine.
Old May 12, 2005 | 06:35 PM
Bimmerman's Avatar
Default Re: (Bimmerman)
k series is the way to go but very $$$
Old May 12, 2005 | 06:37 PM
Rednas's Avatar
LS1
Old May 12, 2005 | 08:11 PM
holotta_eg's Avatar
Default Re: (F+)
b20 is good but b18 will do just fine. i had the same setup but with a b16 tranny 7lb flywheel and stage 3 clutch. i went with the b18a bottom cheap with low miles so i really couldnt pass it up. good luck
Old May 12, 2005 | 10:13 PM
Default Re: (holotta_eg)
well doing the swap isnt a big deal....i have to pull the motor anyways bc the tensioner bolt on the timing belt is stripped and i cant change it unless the motor is out. have any of you guys dealt with a b20 mated with a type r tranny?
Old May 12, 2005 | 10:16 PM
Stoich EG2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F+ &raquo;</TD></TR><TR><TD CLASS="quote">LS1 </TD></TR></TABLE>
hahahaha, there's no torque though
Old May 13, 2005 | 06:13 PM
Default Re: (Advan06)
Old May 15, 2005 | 06:10 PM
Old May 15, 2005 | 06:20 PM
LoganMantits's Avatar
i have an h22 and absolutly love it. torque is amazing pulls hard as hell for n/a
Old May 15, 2005 | 07:41 PM
Default Re: (LoganMantits)
well im not lookin to go h22...wnat to stay b series
Old May 16, 2005 | 09:20 PM
P-DuBB's Avatar
b20
Old May 16, 2005 | 09:39 PM
The Internet Tough Guy's Avatar
Default Re: (P-Dubb)
keep everything you have and just swap that b16 bottom end out for the b20z. you have to run an oil line and some other stuff for a b20 / vtec but it's not too difficult. while you've got the b20 block out of the car upgrade the rod bolts!!!
sell the b16 block and it shouldn't cost you tooo much to do.
Old May 16, 2005 | 10:55 PM
Capt. Jimbo McSubipants's Avatar
Default Re: (The Internet Tough Guy)
i say b20 vtec...but i heard its more then just putting an oil line to the head and what not..i heard valve clearances become an issue and of course the obvious rod bolts and what not..CRVtec should be well thought out before just jumping into it espially if you going to "daily" drive this vehicle...
I have an LS right now...and a Vtec head in my garage..i thought day in a day out to vtec that damn LS...but its a hardcore daily driver..so i chose to sell the head and b16 block...its up to you tho..i'd heard amazing things on the B20z-the higher compression one? with the ITR trans...sick torque...
never had H22..but i imagine its crazy in a lil Eg or EK..
Old May 16, 2005 | 11:08 PM
JFP's Avatar
JFP
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Internet Tough Guy &raquo;</TD></TR><TR><TD CLASS="quote">keep everything you have and just swap that b16 bottom end out for the b20z. you have to run an oil line and some other stuff for a b20 / vtec but it's not too difficult. while you've got the b20 block out of the car upgrade the rod bolts!!!
sell the b16 block and it shouldn't cost you tooo much to do.</TD></TR></TABLE>
Sounds like good power and torque there.......
Old May 17, 2005 | 12:42 AM
D16Z6racing's Avatar
Default Re: (Jpamonag)
Willing to lose high end and rev's, think about a B20B longblock? Around 20hp less than a B20Z, but much lower C/R...maybe turbo down the road?
mike17181
Aug 15, 2012 06:14 PM
canavader
Nov 6, 2007 11:43 AM
karma_33
Mar 30, 2006 10:38 AM
bleedblue94
10
May 15, 2005 06:11 PM
ANGIKEV
Feb 13, 2004 10:38 PM
