walbro fuel pump install -> scared
Old May 12, 2005 | 05:48 PM
type Gendy's Avatar
Default walbro fuel pump install -> scared
Whats the deal with the wires just dangling in there and floating in gasoline? That sounds like a ticking bomb?
I cut the harness they provided almost in half, and soddered it to the remaining pump wires...but the harness was still about 6 inches long. Either way, those wires are gonna be submerged. IN the installation kit, they only provide you with crimps which would not keep the connections dry....
I dont get how these wires can be submerged in gasoline??
Old May 12, 2005 | 07:30 PM
blackeg's Avatar
Default Re: walbro fuel pump install -> scared (type Gendy)
bump
Old May 12, 2005 | 07:54 PM
blkgsr03's Avatar
Default Re: walbro fuel pump install -> scared (blackeg)
why would they make u cut wireS! it should be plug n play!
Old May 12, 2005 | 08:16 PM
Ricey McRicerton's Avatar
Default Re: walbro fuel pump install -> scared (CTRb18c)
I didn't have to cut anything when I installed mine. What the hell did you do?
Old May 12, 2005 | 08:19 PM
2Point3LiterVTEC's Avatar
did you put shrink tubing over your soldered connections?
Old May 12, 2005 | 09:13 PM
fkncivic's Avatar
Default Re: walbro fuel pump install -> scared (Ricey McRicerton)
my walbro was plug and play man i dunno what to tell ya
Old May 12, 2005 | 09:21 PM
drunknbass's Avatar
Default Re: walbro fuel pump install -> scared (fkncivic)
dont worry about it man. its fine as long as your wires dont spark together your ok
Old May 12, 2005 | 09:47 PM
Luserkid's Avatar
Default Re: walbro fuel pump install -> scared (drunknbass)
Theres no air in the gas to make it catch fire. The fumes are what catches fire. So being submerged under gas wont cause a spark. What shocked me was how it keeps a good connection, i still dont get that but i guess its not the same as water. ::shrugs:: its all chemistry and such i never understood it.
Anyway you shouldnt have cut the harness i know in the manual it says to cut a harness but thats for some cars, and honda's arent in that list. As long as the 2 wires arent touching youll be fine though.
Old May 13, 2005 | 05:36 AM
type Gendy's Avatar
Default Re: walbro fuel pump install -> scared (Luserkid)
Because they give u the harness that plugs into the pump then it goes into two stray wires. YOu have to cut off the connectors on the stock pump and sodder the wires together. (this is on a crx though, do 92+ have a clip on the fuel pumps?)
So i did heat shrink the connections but i dont think they are water/gas proof. Had to use really big tubing and couldnt get it quite tight enough. However there is no chance of the two connections touching and making a spark. So as long as they cant tough together and short them i'm fine? The power wire is ok being subermged in gas? weird concept but i guess i can understand.
Edit: What about fumes from a low tank on a hot day in the sun all day? Then you crank it over and gas fumes meet electical connections?
Old May 13, 2005 | 07:27 AM
mrnicolas's Avatar
mine was plug and play also. took like 20 minutes total.
Old May 13, 2005 | 07:31 AM
HatchBox's Avatar
Skoobie no more...
gendy, why would you post this in here, our cars are set up different then a EG. . .
Old May 13, 2005 | 07:35 AM
Evanmb44's Avatar
Default Re: walbro fuel pump install -> scared (HatchBox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">gendy, why would you post this in here, our cars are set up different then a EG. . .</TD></TR></TABLE>
thats what i was thinking
Old May 13, 2005 | 07:40 AM
HatchBox's Avatar
Skoobie no more...
Default Re: walbro fuel pump install -> scared (Turboaddict)
i guess those gas fumes really did a number on him
Old May 13, 2005 | 07:45 AM
Happyman's Avatar
Cause the EG guys are smarter than the EF guys ^_^
Old May 13, 2005 | 07:53 AM
HatchBox's Avatar
Skoobie no more...
Default Re: walbro fuel pump install -> scared (Happyman)
you drive a Egg
haha hopefully you have a sence of humor like the ef guys
Old May 13, 2005 | 08:14 AM
euclid's Avatar
i just had to plug mine in, no cutting or crimping wires to sit in the gas
Old May 13, 2005 | 09:27 PM
type Gendy's Avatar
Because i didnt know they were that much different and eg+ gets 10x the traffic the gay ef forum does. And i was looknig for some quick advice before i blew myself up. DRove it back to my apt 1 hr+, still alive Next thing to try is a full tank
september1951
May 22, 2017 11:39 PM
black_krix_si
Jan 7, 2008 02:00 PM
no1knows908
Sep 7, 2007 05:14 PM
turbo boost
Mar 15, 2007 04:54 PM
type Gendy
Nov 5, 2005 01:52 PM
