Which would be a better Frankenstien?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2genTegSlymm »</TD></TR><TR><TD CLASS="quote">? H22A Head & GSR Block ?</TD></TR></TABLE>
i would like to see you make this combo happen
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob »</TD></TR><TR><TD CLASS="quote">i would like to see you make this combo happen
.......</TD></TR></TABLE>
Werd. LOL
Anyway, though i never seen a flow bench test (you could probably find some if you hunted), many say the B16 head out flows the GSR slightly. So your idea of GSR head on a B16 block may a bit backwards. And most obviously, if a GSR block is available to you, why would you want to consider the 1.6 B block?
GSR head + B16 block = 1.6L with decent flow
B16 head + GSR block = 1.8L with slightly better flow
Which would you rather have???
Head swaps seem to be tricky little critters, so research, research, research. Changing heads affects things like CR and there are also ECU issues (IAB on the GSR etc.)
Wish I could tell you more, but I just don't have the experience in this area. Just do your homework if you're actually gonna build a Frank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by someone I can't remenber »</TD></TR><TR><TD CLASS="quote">Failing to plan = planning to fail</TD></TR></TABLE>
Modified by OBD1Kenobe at 4:44 AM 5/13/2005
.......</TD></TR></TABLE>Werd. LOL
SpoonEk253
Apr 14, 2006 04:35 PM
