STS Turbo
Old May 12, 2005 | 02:37 PM
nd4spd135's Avatar
Default STS Turbo
Wanted to know everyones option on the sts turbo and if it is any better than an normal front mount turbo.
Modified by nd4spd135 at 4:53 PM 5/12/2005
Old May 12, 2005 | 02:49 PM
Aphelion's Avatar
Default Re: STS Turbo (nd4spd135)
decent idea, too expensive...
if you wanted, you could probably homemake this system without too much trouble, if you're good with a welder.
Old May 12, 2005 | 02:55 PM
nd4spd135's Avatar
Default Re: STS Turbo (Aphelion)
I couldn't find a price on the sts kit for a civic but the gto and camaros run from 3-4G...and Im not a good welder.
Old May 12, 2005 | 03:47 PM
_gurusan_'s Avatar
I would think it would be laggy
Old May 12, 2005 | 03:53 PM
nd4spd135's Avatar
Default Re: STS Turbo (_gurusan_)
on thier web site it says its not because the tubing is smaller at the turbo end which forces the air more than if it were all one size.
Old May 12, 2005 | 03:55 PM
_gurusan_'s Avatar
it just seems like it would be laggy...
I mean...imagine flooring it...you have to wait for the exhaust to travel to the back of the car....start spooling the turbo....then wait for boost to build up in a pipe that travels from the back of the car to the throttle body???
Seems like a lot of damn piping to me.
Old May 12, 2005 | 04:03 PM
nd4spd135's Avatar
as long as you pushing the gas dosent air stay in the pipes....even if your only at like 2000rpm
Old May 12, 2005 | 05:03 PM
93Civac's Avatar
Default Re: (nd4spd135)
I copied this directly from there website in the frquently asked questions area
With the turbo so far back, don't you get a lot of turbo lag?
No, our turbochargers are sized to operate at this remote location. Just like any turbocharger, once the turbo is up to temperature and in the rpm range for which it was designed to operate. The boost comes on hard and fast. All of our systems will produce full boost below 3000 rpm.
If you were to take a conventional turbo and place it at the rear, you would have lots of lag and consequently, our turbo wouldn't work properly if mounted up front.
Back to Top
Old May 12, 2005 | 05:15 PM
93Civac's Avatar
Default Re: (93Civac)
I think they are pretty good kits. Look at the kit for the GTO They made 404 WHP and 464 torque at 4 PSI. The car stock makes 291 WHP and 311 torque. They used the stock computer and injectors etc. All they did was put the kit on. Heres a link http://www.ststurbo.com/gto_dyno
Im looing forward to seeing what the kit does that they are making for the Civic and the ITR.
Old May 13, 2005 | 02:38 PM
nd4spd135's Avatar
on the web site is shows and ITR taking off...looks a little slow but that is compared to the camaro and the gto
stunn'd
Apr 11, 2008 08:37 PM
aja345
16
Apr 20, 2007 06:04 PM
ykracing
Mar 26, 2004 05:06 PM
pub
Mar 26, 2003 01:14 PM
blufke
Oct 11, 2002 03:37 PM
