how to build a 1.9l b16
Old May 12, 2005 | 01:55 PM
teefunk01's Avatar
Default how to build a 1.9l b16
ls crank...is that all I need? what exactly does the machine shop have to do?
Old May 12, 2005 | 02:29 PM
Innovation's Avatar
Default Re: how to build a 1.9l b16 (tphan4)
LS crank, B16 rods, custom piston with a .955 compression height and .748 wrist pin in your choice of bore (ranges from STD - 82mm with unsleeved block), rods rebushed to accept .748 pin
R/S ratio will be 1.51, a very minumal decrease in rod angle from the stock LS 1.54...
Going this route keeps the pin bore out of the oil ring groove and allows you to run a lightweight strutted skirt piston.
AJxr
Jul 25, 2009 03:07 PM
CTR_B
Oct 17, 2008 04:19 PM
hOndafienD 04
Apr 6, 2005 08:42 PM
ensracer
Apr 14, 2004 07:45 PM
b16vtecsol
Jan 17, 2004 07:23 PM
