my accord shudders when i accelerate..what can it be
Old May 12, 2005 | 04:42 AM
motormanSR's Avatar
Default my accord shudders when i accelerate..what can it be
when i accelerate in (any gear) ... my honda will shudder in the lower RPMs...it acts as if it was stalling but it's not..my power is close to nothing in the lower rpm but once i get over 2700 i am good to go.....
i tried all the typical stuff..changed my air filter as well as my feul filter as well as my spark plugs..my complete exhaust system is less than a year old (all stock)
what can you guys suggest next...
Old May 12, 2005 | 06:25 AM
deserthonda's Avatar
what yr and model???
Old May 12, 2005 | 07:59 AM
Turbowa's Avatar
Default Re: my accord shudders when i accelerate..what can it be (motormanSR)
Also is it an auto or 5spd?
Old May 12, 2005 | 08:04 AM
motormanSR's Avatar
Default Re: my accord shudders when i accelerate..what can it be (Turbowa)
my bad ......1995 honda accord ex, coupe, 5 speed, 256k miles..... she has been faithful..
Old May 12, 2005 | 03:35 PM
plug wires?? bad motor mount, bad inner axle joint, plugged egr ports,,
Old May 12, 2005 | 03:39 PM
any timing belt work done recently??
Old May 12, 2005 | 04:47 PM
drifter_for_life06's Avatar
Default Re: (deserthonda)
either a kink in the fuel line that is suffering the motor at lower speeds and starving you of fuel or you have bad ignition somewhere
Old May 13, 2005 | 03:09 AM
motormanSR's Avatar
i just changed both my front axles...so i know that they are good..i know that one of my mounts is bad and i planned on changing it this weekend...how do i go about cleaning egr ports?
also..i did change my timing belt two weeks ago but it was doing it before i changed the belt... i should also add that it also does the shuddering thing even when going down hill....i already checked that i am getting spark to all four plugs..what the best way to chase down a spark problem?
thansk again guys
Old May 16, 2005 | 03:13 AM
motormanSR's Avatar
cleaned EGR this weekend...problem is still there..what next?
Old May 16, 2005 | 04:21 AM
NBPcivic07's Avatar
Default Re: (motormanSR)
i had this prob awhile back i ended up buying new plugs and wires and it fixed the prob i say buy new plugs 1st that should do it
Old May 16, 2005 | 07:51 AM
Turbowa's Avatar
Default Re: (crableg03)
When was the last time the clutch was replaced? It could be that the flywheel and pressure plate have some many hot spots on them and are just too worn out.
Old May 16, 2005 | 11:19 AM
motormanSR's Avatar
Default Re: (Turbowa)
it's been a while seinced the clutch was replaced but i doubt that's the problem..she hold up pretty good at high RPM...i can still smoke my tires if i want to...this problem also happens when i am going down hill so i am sure it's not a problem with the power load..the electrical path seems to make more sence.. i already changed the spark plugs..and it did nothing
Old May 16, 2005 | 11:49 AM
was problem there berfore replacing axles??
Old May 16, 2005 | 05:07 PM
VTECsop's Avatar
same exact thing happen to my 95 ex 5spd. i bet that its the map sensor
Old May 17, 2005 | 04:07 AM
motormanSR's Avatar
Default Re: my accord shudders when i accelerate..what can it be (VTECsop)
the problem was there before i replaced the axles...i will look in to the map sensor...i did check at 4 plugs and i am getting good spark...
Old May 23, 2005 | 05:01 AM
motormanSR's Avatar
problem fixed...FYI.. it was the spark plug wires..i think they were around 100K old
kevbo06
Apr 26, 2010 12:31 PM
chevydriver
Aug 26, 2008 07:46 AM
Bear Down
Nov 21, 2005 08:16 PM
abeaujuin
Mar 15, 2004 09:05 PM
