Engine sputter
Old Apr 14, 2010 | 11:22 AM
kevbo06's Avatar
Default Engine sputter
Sorry guys this is my first post so this might seem kinda trivial.
Car: 92' Accord EX manual Trans all stock
When I am accelerating in any gear other than first, I get an unconformable jerking anywhere from 1000 to 2500 RPM. Anyone think they might know what it is? 256K miles on it and the timing belt needs to be changed but i cant afford it at the moment. if you need more information let me know.
Old Apr 14, 2010 | 01:42 PM
alkoholikwun's Avatar
Default Re: Engine sputter
probably just the usual maintenance, spark plug/wires, fuel filter/pump, timing.
Old Apr 14, 2010 | 08:41 PM
Atreidies's Avatar
Check your timing with a timing light, and check your motor mounts.
Old Apr 15, 2010 | 07:26 PM
McPhaty's Avatar
i agree plugs wires fuel filter cap and rotor and an oil change, just for good messures!
Old Apr 15, 2010 | 08:12 PM
quickster's Avatar
Check your cap and roter points.
Old Apr 25, 2010 | 08:45 PM
kevbo06's Avatar
for some reason i am thinking that i could need to clean my fuel injection line. I was told about 3 months ago that i have carbon build-up that needs to be cleaned but I cant afford to get it done. any thoughts? It is getting worse by the way. I only drive short distances. and it seems to be knocking worse around 2K RPM.
Old Apr 25, 2010 | 08:51 PM
1cln_eg9's Avatar
change plugs, wires, cap, and rotor! then stop at the shell gas station and fill up on the highest octane fuel they sell that should clear it up
Old Apr 26, 2010 | 12:31 PM
Atreidies's Avatar
Does your engine have any problem accelerating in neutral? Do you have this problem above 2500 rpm's in your other gears?
carlosd68
12
Sep 28, 2012 08:07 PM
johnny090881
Jun 7, 2009 10:56 PM
chevydriver
Aug 26, 2008 07:46 AM
jizzer671
Jun 2, 2005 12:40 AM
4drNrunnin
Oct 11, 2004 11:24 PM
