4x100 to 4x114.3 conversion the easy way. will this work?
Old May 11, 2005 | 08:15 PM
stockegsix's Avatar
Default 4x100 to 4x114.3 conversion the easy way. will this work?
As far as I know the rear disks setup from a GSR and 96 spec JDM ITR are the same except for the bolt pattern. Now If I was to do a conversion and instead of talking the whole trailing arm and doing all that ****. Can I just swap out this part?
the one with the arrow
bigger pic
fits on the new wheels just need some red lug nuts
Old May 11, 2005 | 08:20 PM
Kendall's Avatar
I thought it was easy enough to just change the trailing arms.
Old May 11, 2005 | 08:23 PM
stockegsix's Avatar
Default Re: (Kendall)
taking off the trailing arm is not easy on jacks stands.
no e- brake removal, no rear brakes bleeding none of that stuff
Old May 11, 2005 | 10:27 PM
eg6sir-s's Avatar
Default Re: (stockdc2)
i told you that wouldnt work. if it did everyone would be swapping out hubs rather than complete suspension. you have the full suspension swap it out.
Old May 11, 2005 | 10:31 PM
SilverDc2's Avatar
Default Re: (eg6sir-s)
try it and find out....
Old May 11, 2005 | 11:11 PM
stockegsix's Avatar
too lazy... why wouldnt it work?
Old May 11, 2005 | 11:23 PM
PandaBear's Avatar
Maybe the size of the hub is different? shaft diameter being different?
Old May 12, 2005 | 12:52 AM
Deluzional's Avatar
Default Re: (PandaBear)
Try it out and let us know. As for me, I kept my stock e-brake lines(my e-brake takes about 5 clicks to fully tension) Id just save myself the trouble and completely switch it over
Old May 12, 2005 | 03:04 AM
jdm_cars's Avatar
Default Re: 4x100 to 4x114.3 conversion the easy way. will this work? (stockdc2)
dude, it will work, but just to let you know, the rear trailing arm parts have different part numbers, unlike the front Knuckles that have the same SR3 part number.
from what I read, the rear spindles on the type r ones stick out more. It would work, but you wouldnt be getting the true type R suspension if you don't swap out the entire trailing arms.
Old May 12, 2005 | 05:54 AM
stockegsix's Avatar
Default Re: 4x100 to 4x114.3 conversion the easy way. will this work? (jdm_cars)
thanks man, well see. I will take it out this saturday. I know the rear calipers are have the same part number. hmmm, I wonder what the difference with the trailing arms?
Old May 12, 2005 | 08:12 AM
dFreezy's Avatar
that rotor has seen better days!
Old May 12, 2005 | 02:14 PM
stockegsix's Avatar
TTT
Nextelbuddy
52
Nov 6, 2005 10:56 PM
stockegsix
15
May 15, 2005 08:46 AM
Silver Ferio
Jun 3, 2004 09:22 PM
daddymax
Sep 20, 2003 08:39 AM
