Differances between auto & manual ECU in EG?
Old May 11, 2005 | 05:22 PM
Jan in Omaha's Avatar
Default Differances between auto & manual ECU in EG?
I am in need of a new ECU for my 92 Civic Si (manual) I believe I need a P28 ECU. Can I use any ECU from 92-95 Si/EX even if it's from an automatic car?
Sorry for the question... but I didn't find it in the search.
Old May 11, 2005 | 06:03 PM
GeeSssAre's Avatar
Default Re: Differances between auto & manual ECU in EG? (Jan in Omaha)
yes u can. you just need to open up the ecu and modify it.
Old May 11, 2005 | 08:48 PM
Default Re: Differances between auto & manual ECU in EG? (GeeSssAre)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GeeSssAre &raquo;</TD></TR><TR><TD CLASS="quote">yes u can. you just need to open up the ecu and modify it.</TD></TR></TABLE>
I guess I now have 2 questions:
Is there a way to tell which is which from the codes on the outside?
How do you modify an auto ecu for a manual?
Old May 12, 2005 | 05:06 AM
Hurricane's Avatar
Try here.
https://honda-tech.com/zerothread?id=1171263
Old May 12, 2005 | 07:27 AM
Default Re: Differances between auto & manual ECU in EG? (Hurricane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hurricane &raquo;</TD></TR><TR><TD CLASS="quote">Try here.
Thanks for the link. That gives the info on the change to mt... but unfortunately nothing on how to tell from the outside of the computer if it's for a m/t or a/t. (so I buy the correct one in the first place and not have to solder anything)
Old May 12, 2005 | 11:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jan in Omaha &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks for the link. That gives the info on the change to mt... but unfortunately nothing on how to tell from the outside of the computer if it's for a m/t or a/t. (so I buy the correct one in the first place and not have to solder anything)</TD></TR></TABLE>
Here's the info I was looking for. (scroll down a little bit to find it)
https://honda-tech.com/zerothread?id=810101
Slamaccord
Jun 18, 2007 03:33 PM
sohc_freak
15
Apr 22, 2006 03:26 PM
Jan in Omaha
10
May 12, 2005 04:43 PM
MonkeyMagic
May 15, 2004 08:32 AM
ek_will
May 4, 2003 07:24 PM
