crankshaft snapped of can it be fixed.
Old May 11, 2005 | 05:00 PM
d15b's Avatar
Default crankshaft snapped of can it be fixed.
Hello I own a 1992 civic the other day the crankshaft snaped in half. I am wondering if this can be fixed and at what price or is it better off buying a whole new engine.
Thanks
Old May 11, 2005 | 05:03 PM
Bcuz's Avatar
Default Re: crankshaft snapped of can it be fixed. (d15b)
Buying a new engine will be cheaper. Sorry for the bad news, cuz.
Old May 11, 2005 | 05:07 PM
Deemeetree's Avatar
Electrician
Unless you can tear the engine apart and do it yourself, getting another engine will be cheaper.
Old May 11, 2005 | 05:17 PM
e jay one's Avatar
Default Re: (Dimi)
get a jdm d15b there cheap and will be easyer that doing a crank job and youll have a lower millage motor.
Old May 11, 2005 | 05:19 PM
Kamin's Avatar
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">Unless you can tear the engine apart and do it yourself, getting another engine will be cheaper.</TD></TR></TABLE>
even replacing the crankshaft will cost more than a "new" used engine. espically a d15
first of all, ive got a couple questions.
how do you know your crankshaft snapped in half? thats VERY hard to do. espically on a stock engine its damn near impossible.
Modified by Kamin at 6:41 PM 5/11/2005
Old May 11, 2005 | 08:08 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
how do you know your crankshaft snapped in half? thats VERY hard to do. espically on a stock engine its damn near impossible.</TD></TR></TABLE>
i would also like to know the answer to this question.
Old May 11, 2005 | 08:11 PM
JDMlyfestyle's Avatar
WTF... Ive never heard of a Stock Honda motor snapping the crank in half. i wanna see pix!!!!
Old May 11, 2005 | 08:14 PM
_gurusan_'s Avatar
Default Re: (JDMlyfestyle)
werd....how the hell did that happen
Old May 11, 2005 | 08:20 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: (_gurusan_)
seriously. A stock Honda crank, even a D series, should last forever, and take probably 20psi of boost, stock. Only problem could be SEVERE wear, like a bad rebuild.
Was a oil like fucked up? Cause lack of lube or a spun bearing could contribute. PICS PLEASE!!!!!
Old May 11, 2005 | 10:04 PM
d15b's Avatar
Default Re: (Redline96LX)
hey the crankshaft has snapped just before where the pulley bolt in connected dont hav cam so cant get pics.
Old May 11, 2005 | 10:14 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (d15b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15b &raquo;</TD></TR><TR><TD CLASS="quote">hey the crankshaft has snapped just before where the pulley bolt in connected dont hav cam so cant get pics.</TD></TR></TABLE>
Oh...just the snout broke off. That's not uncommon in high mileage engines. Just buy a junkyard motor for $300 and you're golden.
Old May 11, 2005 | 10:48 PM
Thateguhate's Avatar
Default Re: (Archidictus)
I just had the samething happen to me, it beat me out of $1100. Timing belt almost fell off. Thought my alternator went out.. turns out my timing was off from when the belt was done it reversed and snapped the pin/pulley right off causing all belts but the timing to come off.
I got owned being it was sidework, with no invoice. My crankshaft sustained minimal damage.
http://www.civicland.com/forum...=6087
my pics of the damage are there, Go thru the whole page....
Old May 19, 2005 | 09:54 PM
Dai_Ca_Vietnam_H22a4's Avatar
Default Re: (Doughboy63)
How many different ways can cause a crankshaft to bend?
Old May 19, 2005 | 10:00 PM
Deemeetree's Avatar
Electrician
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doughboy63 &raquo;</TD></TR><TR><TD CLASS="quote">I just had the samething happen to me, it beat me out of $1100. Timing belt almost fell off. Thought my alternator went out.. turns out my timing was off from when the belt was done it reversed and snapped the pin/pulley right off causing all belts but the timing to come off.
my pics of the damage are there, Go thru the whole page....</TD></TR></TABLE>
Sorry boss, you got ripped.
TedK616
May 29, 2017 04:49 PM
TedK616
May 29, 2017 04:46 PM
powerpuff
Nov 1, 2013 11:50 AM
msinsky14
Jun 8, 2006 05:50 PM
lilcasino
Oct 2, 2002 06:58 PM
