crankshaft snapped of can it be fixed.
Hello I own a 1992 civic the other day the crankshaft snaped in half. I am wondering if this can be fixed and at what price or is it better off buying a whole new engine.
Thanks
Thanks
Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">Unless you can tear the engine apart and do it yourself, getting another engine will be cheaper.</TD></TR></TABLE>
even replacing the crankshaft will cost more than a "new" used engine. espically a d15
first of all, ive got a couple questions.
how do you know your crankshaft snapped in half? thats VERY hard to do. espically on a stock engine its damn near impossible.
Modified by Kamin at 6:41 PM 5/11/2005
Multi-paradigm
Re: (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">
how do you know your crankshaft snapped in half? thats VERY hard to do. espically on a stock engine its damn near impossible.</TD></TR></TABLE>
i would also like to know the answer to this question.
* B A N N E D *
1 Post
Re: (_gurusan_)
seriously. A stock Honda crank, even a D series, should last forever, and take probably 20psi of boost, stock. Only problem could be SEVERE wear, like a bad rebuild.
Was a oil like fucked up? Cause lack of lube or a spun bearing could contribute. PICS PLEASE!!!!!
Unceasing Measure
Re: (d15b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15b »</TD></TR><TR><TD CLASS="quote">hey the crankshaft has snapped just before where the pulley bolt in connected dont hav cam so cant get pics.</TD></TR></TABLE>
Oh...just the snout broke off. That's not uncommon in high mileage engines. Just buy a junkyard motor for $300 and you're golden.
1 Post
Re: (Archidictus)
I just had the samething happen to me, it beat me out of $1100. Timing belt almost fell off. Thought my alternator went out.. turns out my timing was off from when the belt was done it reversed and snapped the pin/pulley right off causing all belts but the timing to come off.
I got owned being it was sidework, with no invoice. My crankshaft sustained minimal damage.
http://www.civicland.com/forum...=6087
my pics of the damage are there, Go thru the whole page....
Electrician
Re: (Doughboy63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doughboy63 »</TD></TR><TR><TD CLASS="quote">I just had the samething happen to me, it beat me out of $1100. Timing belt almost fell off. Thought my alternator went out.. turns out my timing was off from when the belt was done it reversed and snapped the pin/pulley right off causing all belts but the timing to come off.
my pics of the damage are there, Go thru the whole page....</TD></TR></TABLE>
Sorry boss, you got ripped.
