Car grinds when going into reverse, clutch or tranny?
Old May 11, 2005 | 03:18 PM
Manolo's Avatar
Default Car grinds when going into reverse, clutch or tranny?
My clutch is almost dead, but I was just wondering this. SOMETIMES when I try to go into reverse it grinds, I dont know if its cause of the dead clutch or could it be the tranny, I pray its not the tranny!
Old May 11, 2005 | 03:38 PM
dividedas1's Avatar
eh my car does it and all of my friends do...what i do is i always shift into 3rd before i go into reverse and it hardly ever grinds
Old May 11, 2005 | 03:45 PM
94sleeperSi's Avatar
Default Re: (dividedas1)
phew. glad im not the only one
Old May 11, 2005 | 03:47 PM
nocturnaldragon's Avatar
Default Re: Car grinds when going into reverse, clutch or tranny? (Manolo)
Its just the way the tranny is geared, dont ask me why but thats perfectly normal...
Manolo's Avatar
Default Re: (94sleeperSi)
You just made my night, thank you!
Old May 11, 2005 | 03:48 PM
civicboisi's Avatar
Default Re: (Manolo)
make sure you foot is pressing the pedal all the way to the floor and the gear is engaged before letting off...the grinding shouldn't occur all the time...
Old May 11, 2005 | 03:54 PM
komat's Avatar
Default Re: (civicboisi)
i go from 1st 2nd then to reverse works everytime
Old May 11, 2005 | 03:59 PM
nub.96ek's Avatar
Default Re: Car grinds when going into reverse, clutch or tranny? (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">Its just the way the tranny is geared, dont ask me why but thats perfectly normal...</TD></TR></TABLE>
It's a straight cut, un-synchronized gear.
Old May 11, 2005 | 04:07 PM
GUNNER666's Avatar
Default Re: Car grinds when going into reverse, clutch or tranny? (nub.96ek)
if you read the manual for your car, it says to go into forward gear before going into reverse.
Old May 11, 2005 | 05:55 PM
Default Re: Car grinds when going into reverse, clutch or tranny? (GUNNER666)
that just aligns the gears since theres no syncro, some cars dont require this all the time tho...
Old May 11, 2005 | 08:12 PM
Daniel san's Avatar
the reverse gear is the only gear with out a syncro, so depending on what gear you were in last, it grinds
just put it in first then reverse.. should be fine,don't need to put it in more then the first gear before going into reverse.
but it's totally normal, they all do that
Old May 11, 2005 | 10:15 PM
Morning Call's Avatar
my car never grinds into reverse.. but sometimes i cant even get into reverse without rolling forward a tiny tiny bit
all i hear is a click going into reverse
Old May 11, 2005 | 10:27 PM
ch4nq's Avatar
weird moving the car foward is able to go to reverse? mines dont do that cause if it even moves it grinds on reverse. i just step on the clutch pedal a few times and it goes right in. if not then hold clutch and put in reverse but not all the way only to the point where it wont let you go in then when you let go of clutch pedal slowly put gear into reverse and it'll snap right in.
Old May 12, 2005 | 01:17 AM
nub.96ek's Avatar
Default Re: (ch4nq)
I just started putting mine in reverse before I even start it if I'm gonna back up.
Old May 18, 2005 | 04:09 AM
HatchEh2's Avatar
Default Re: (nub.96ek)
DONT MOVE! make sure the car is at a dead stop, pedal ALL the way down, then put it in. It tells you to do so in your manual.
It SHOULDNT grind, but it wont hurt it THAT much. just **** around with it and youll find a way thats convenant to you to get it in w/o the grinding
Old May 18, 2005 | 05:17 AM
jolt-tsp's Avatar
Default Re: (HatchEh2)
If you're moving don't even try, it will grind unless you're just a god at rev matching.
Old May 18, 2005 | 08:20 AM
doughboy_88's Avatar
you can do the "forward gear first and then shift into reverse" without moving.
or you can do what i do...depress the clutch for a few seconds and then shift into reverse. it never grinds when i do that.
Old May 18, 2005 | 08:25 AM
DxBurnoutKing's Avatar
reverse gear is straight cut hence why it whines really loud when they are in motion.
Old May 18, 2005 | 09:21 AM
EJ6_Hatch's Avatar
Default Re: (DxBurnoutKing)
you can get it into reverse while you are moving as long as you are moving backwards. I know I have done it a few times while rolling out of friends drive ways.
mine really doesnt grind unless i didnt get it all the way into gear to begin with, but sometimes I have to do the forward gear trick before I can get it into R.
globy123
Jun 20, 2008 10:54 AM
jdm94eg
Apr 3, 2005 06:53 PM
Synergy001
Dec 7, 2003 09:42 AM
1hotvtec
Oct 14, 2003 12:31 AM
MrBite
Jun 13, 2002 12:48 PM
