crank removal.. help plz...
Old May 11, 2005 | 12:49 PM
4LugR's Avatar
Default crank removal.. help plz...
how do i remove the crank from the block, the flywheel mount prevents it from moving.... anyone kno how to remove the crank???
Old May 11, 2005 | 10:46 PM
4LugR's Avatar
Default Re: crank removal.. help plz... (AEMPrelude916)
come on guys, a lil helppp....
Old May 12, 2005 | 04:38 AM
PirateMcFred's Avatar
You realize that that is MAJOR surgery and you basically have to remove *everything* to get it out.
Once you get the thing stripped down to the longblock then you need to remove the timing junk, oil pan, flywheel, rear main seal plate, oil pump and then rods and main bearing caps. After you get that accomplished then it should fall out.
Sorry to say that beyond that advice you should go and buy a Helms manual to get the junk back together.
Pirate
managon_5
Mar 23, 2009 08:07 PM
tei344
Sep 19, 2007 02:29 PM
Finger Lickin' good
Aug 30, 2005 07:45 PM
Maddox
Mar 1, 2004 09:05 AM
Akira-R
Jul 29, 2001 12:00 PM
