Coolant Overflow Nipple
Old May 11, 2005 | 12:24 PM
jdmkrazie's Avatar
Default Coolant Overflow Nipple
ok so the coolant overflow nipple on the radiator broke off. is there anything i can use to glue it back on or do i have to get a new radiator?
Old May 11, 2005 | 12:44 PM
Perfectionist's Avatar
Default Re: Coolant Overflow Nipple (jdmkrazie)
Since it's only the overflow (no pressure involved), I would think a glue specifically for plastics might work OK. Just be sure to get a good seal so the rad doesn't suck air when the liquid cools down.
Old May 11, 2005 | 12:54 PM
jdmkrazie's Avatar
Default Re: Coolant Overflow Nipple (Perfectionist)
sounds good i was hoping it would be ok. i'll go ahead and try that today and see how it turns out
Old May 11, 2005 | 01:31 PM
CRXDrew's Avatar
JB weld is ur friend.
Old May 11, 2005 | 09:34 PM
Finger Lickin' good's Avatar
Default Re: (CRXDrew)
jb weld or bust. thats under pressure, glue will last a day.
Old May 11, 2005 | 10:03 PM
jdmkrazie's Avatar
Default Re: (D-CeReaL#4)
i used some kind of epoxy for plastic... so far its working ok. not leaking or anything. just gotta see how it does for a long drive. hopefully everything will be ok.
Old May 12, 2005 | 12:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-CeReaL#4 &raquo;</TD></TR><TR><TD CLASS="quote">jb weld or bust. thats under pressure, glue will last a day.</TD></TR></TABLE>
Ummm...,try again.
The overflow nipple directs the coolant that escapes from under the radiator cap into the overflow bottle when the system pressure and coolant expansion is high enough. When the system cools enough, the contraction of the coolant creates a vacuum and sucks the excess back into the system. The only critical part about glueing is to make sure there are no pinhole leaks.
Old May 12, 2005 | 01:25 PM
tonis56's Avatar
Default Re: (Perfectionist)
i do believe that Gates, the same company that makes hoses and belts, makes a repair kit for this exact prob. hope this helps
Old May 13, 2005 | 12:43 PM
jdmkrazie's Avatar
Default Re: (tonis56)
ok well everythings been good so far. the stuff is holding up pretty good
Old May 13, 2005 | 05:19 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmkrazie &raquo;</TD></TR><TR><TD CLASS="quote">ok so the coolant overflow nipple on the radiator broke off. is there anything i can use to glue it back on or do i have to get a new radiator? </TD></TR></TABLE>
Superglue works well if you clean both pieces real good.
Ser1N
Oct 30, 2008 11:54 AM
bokals
Mar 8, 2007 07:04 PM
TOO MUCH TORQUE
Feb 4, 2007 07:50 PM
IntegraTionR
Sep 18, 2005 08:22 PM
Loveless
Jul 14, 2003 03:22 PM
