Wiring gauge power to dimmer?
I wired up my boost and EGT gauge illumination power to the solid red wire of the dimmer switch. This is the variable output of the dimmer switch I measured to make sure I was tapping the right source. This is on an EK hatch BTW. Gauges work but when it was time to test the illumination, we ran into a problem.
The cluster illumination brightens or darkens opposite to the new gauges depending on where the dimmer is adjusted. If set at MAX, the boost and EGT are fully bright but the cluster is dim. Somewhere in the middle and the cluster is dim and the new gauges are super dim. Can't live with that or illumination that is going to be super bright if wired to constant 12V.
The cluster is fused for 7.5A. I don't think I am adding that much. My other option is the wire in a seperate circuit from a constant 12V and run another pot to control the illumination to the new gauges. But I am hoping you guys with gauges already have a solution.
BTW, i searched
BTW, i searched
For my 96 gsr, connect positive wire from the gauge light to solid red wire of the dim switch and connect negative wire from gauge light to red w/black stripe wire of the dim switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by porsche997 »</TD></TR><TR><TD CLASS="quote">For my 96 gsr, connect positive wire from the gauge light to solid red wire of the dim switch and connect negative wire from gauge light to red w/black stripe wire of the dim switch.
did you happen to measure the voltage to those 2 wires? and where was your ground refernce? on my EK, the center wire (black) is ground, the solid red is the variable dimmer output and the red w/ stripe wire is the switched 12V. If I did that to my wiring, i would essentially be bypassing the dimmer. I could be wrong....dunno?!? I'll recheck.
</TD></TR></TABLE>did you happen to measure the voltage to those 2 wires? and where was your ground refernce? on my EK, the center wire (black) is ground, the solid red is the variable dimmer output and the red w/ stripe wire is the switched 12V. If I did that to my wiring, i would essentially be bypassing the dimmer. I could be wrong....dunno?!? I'll recheck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drunknbass »</TD></TR><TR><TD CLASS="quote">all i know is i just had to wore up a dimmer and it was a ground. so that might be 1/2 your prob.</TD></TR></TABLE>
i don't understand what you're trying to tell me.....
ok.. i havea jdm eg6 hatchback. the jdm cars/clusters dont operate with a dimmer, because the cars dont have dimmers. well i had to put in a regular us eg cluster in my jdm car and the cluster didnt light up with the headlights. so i looked at the dimmer spot on the plug and noticed my car (same as all jdm eg6's) doesnt have a wire in the dimmer pin on the harness. so i just plugged a + into the spot where the dimmer wire would run, then i noticed the cluster lights were opposite the headlights. if my headlights were off my cluster lights were on, and vise versa.. so i ran a ground into the dimmer pin area on the cluster instead. and the light on the cluster are now hw they should be, they go on with the headlights.
Mister Jew
Sep 22, 2006 05:55 PM
MBlake55
May 16, 2006 07:20 AM
ActiveAero
Oct 23, 2005 06:52 AM
Laserjock
May 12, 2005 05:53 PM
