Honda S2000 Honda S2000
cv joints - symptoms of failure?
Old May 9, 2005 | 09:51 AM
Mr. Bagel's Avatar
Default cv joints - symptoms of failure?
has anyone had their cv joints fail on the rear axle? If so, what are the symptoms you have experienced?
Old May 9, 2005 | 10:00 AM
evil vapor's Avatar
Default Re: cv joints - symptoms of failure? (Mr. Bagel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Bagel &raquo;</TD></TR><TR><TD CLASS="quote">has anyone had their cv joints fail on the rear axle? If so, what are the symptoms you have experienced?</TD></TR></TABLE>
never had any failures but from past experiences noises will be apparent mostly under turning one direction or another. If the joints are really bad, then they will make noise going straight. Do figure 8's in a parking lot at low speed and vary throttle position while turning. That'll tell you which side is the problem without pulling the halfshafts out and inspecting them.
Old May 9, 2005 | 10:04 AM
Mr. Bagel's Avatar
Default Re: cv joints - symptoms of failure? (vapor)
click click? will it be consistent? or vary?
Old May 9, 2005 | 10:14 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Bagel &raquo;</TD></TR><TR><TD CLASS="quote">click click? will it be consistent? or vary?</TD></TR></TABLE>
clicks in the beginning if you catch it early, otherwise it'll be creaking rumbling like rolling a lumpy stone on a smooth surface. The clicks should vary with your speed.
Old May 9, 2005 | 10:25 AM
Mr. Bagel's Avatar
I don't hear clicking when I'm driving at all. I do get some creeks when I drive off from a dead stop. They come from the left rear from what I can hear, but.. I'm unsure exactly, which is why I'm asking about symptoms. I do not have a rear swaybar on the car, which might allow the rear to behave properly, but also, provide some creeks that are not in stock form. I should be able to take a closer look later this week.
Old May 12, 2005 | 02:53 PM
p nut's Avatar
Have you noticed any grease drippage from the rear joints? I'd check to see if the boots are torn. If you don't hear any popping or clicking when turning, your CV joints are probably still ok.
Old May 12, 2005 | 03:01 PM
Mr. Bagel's Avatar
Default Re: (P Nut)
ahhh thanks. I'll definately give it a shot. While turning - no. Only a few creeks upon take off, but never while turning.
Old May 13, 2005 | 04:25 AM
s2kds's Avatar
i had some problems with my dr. side. As you guys know im bringing a salvage back to life. First just try tightening the spindle nut i think its to like 210 ft lbs. My problem was one of the cv bearings "poped" out of place and was sitting in the bottom of the housing. Personally I would take it off and inspect it. then buy the proper rebuild kit. (just to be safe.) -hope that helps-
Old May 13, 2005 | 07:16 AM
Mr. Bagel's Avatar
Default Re: cv joints - symptoms of failure? (s2kds)
yup that does help. I'll look further into it.
Old May 13, 2005 | 09:39 AM
jolt-tsp's Avatar
This happened on my brother car. It was so bad that the car couldn't move. Sounded like a toy machine gun whenever he'd try to go. Had to tow it back home.
xanonymousx
Oct 24, 2007 03:14 PM
Ideal
Apr 5, 2005 11:40 PM
nitrousrush
Sep 2, 2004 12:07 PM
Supraznki
Jul 16, 2004 08:49 AM
RabbittZ
11
Jun 27, 2003 09:09 PM
