Why is it that some turbo kits out there don't require ECU changes?
Old May 8, 2005 | 06:29 PM
ajusaf's Avatar
Default Why is it that some turbo kits out there don't require ECU changes?
like some kits that provide everything but usually is set to only boost at 7 psi come with everything and they don' even recommend or tellyou you have to change your ECU or update it etc..?
Old May 8, 2005 | 06:38 PM
BlueShadow's Avatar
Default Re: Why is it that some turbo kits out there don't require ECU changes? (ajusaf)
Probably cause the kits have FMU or AIC setups both of which dont require you to do anything withyour stock ECU.
Old May 8, 2005 | 06:39 PM
wantboost's Avatar
Who is Mr Robot?
thats because most kits give you an fmu and a missing link, which is a shitty solution to engine management.
most people prefer to use an engine management system they like, such as aem, apexi, uberdata, hondata etc.
slowata
Jun 6, 2007 01:43 PM
LU
Feb 9, 2007 10:04 AM
gsr_pimp88
Oct 27, 2006 08:25 PM
Metal Typhoon
Jun 11, 2006 08:32 PM
rocket256
May 8, 2004 11:19 AM
