ek throwing a code
Old May 8, 2005 | 03:37 PM
drowzysleeper's Avatar
Default ek throwing a code
ever since i put on my test pipe, my check engine light has been on my car is an obd2 and there is a o2 sensor in my cat, i put it in the test pipe and of course im still throwing the code does any one know how to get rid of the code? i have also tried resetting my ecu it goes away until the exhaust heats up, what else can i do?
Old May 8, 2005 | 03:38 PM
jlacoy82's Avatar
71.192.16.183
Default Re: ek throwing a code (drowzysleeper)
Run an O2 simulator for the rear o2 sensor, or take off your test pipe which is giving you approximately .00023 HP.
Old May 8, 2005 | 06:22 PM
Default Re: ek throwing a code (jlacoy82)
yeah i would put the stock cat on but it is sooo rusty the bolts would probably break. i think the stock cat would probably make me lose hp though since it is a smaller diameter. what do you think?
Old May 8, 2005 | 07:08 PM
bump
Old May 10, 2005 | 01:55 PM
bump
InTheZoneAC
Jan 7, 2013 02:22 PM
Dashu
Jul 7, 2006 10:25 AM
sickofitall1113
Jun 9, 2005 12:18 PM
ORcivicsi
Apr 11, 2005 06:02 PM
