Finally got 1/4 times for my LS coupe
Old May 8, 2005 | 12:56 PM
itsJDMyo's Avatar
Default Finally got 1/4 times for my LS coupe
finally had the chance to run my car at Portland International Raceway last night. it wasn't that packed, i managed to get 8 runs in. my best run was 14.9.
R/T....200
60'.....2.376
330....6.335
1/8....9.662
MPH...73.91
1000..12.528
1/4....14.975
MPH...90.77
mods are as follows:
***96' LS motor in a 95' civic coupe***
-jdmsh!t 4-1 header w/2.5" collector
-buddy club spec-III exhaust
-onmipower testpipe
-ebay CAI w/KN filter
-exedy stage 1 clutch kit
-chipped pr4 ecu
-L-con traction bar (for some reason, my tires hit the bars when i turn to far to the left or right )
i know i can do better, because my 60' isn't that great...i still get a lot of wheel hop for some reason though.. i bought a traction bar, motor mount inserts, also an NRG torque damper. for some reason, i still get wheel hop...could it be my suspension? someone mention that if you have bad suspension, then it could cause it also. i'm just running on stock struts with dropzone coilovers. i also lowered the PSI of my tires to 33, but that didn't help much....my main goal right now, is just to get rid of the wheel hop...
so what do you guys think of the 1/4 time? i think it's a pretty good time.
BTW, my car just got broken into this morning around 11-12 at my ****** church!! they only took my cd player though...
Old May 8, 2005 | 01:04 PM
hatch34's Avatar
Default Re: Finally got 1/4 times for my LS coupe (itsJDMyo)
thats a pretty good time how much does it weigh my buddy only only got 14.8 and he has LS in a hatch so you did damn good bein in a coupe
Kyles ej1's Avatar
i think u could definately get lower, what tranny are u using?
as for the wheel hop, do u just dump the clutch? if so try slipping it next time
Old May 8, 2005 | 01:54 PM
itsJDMyo's Avatar
Default Re: Finally got 1/4 times for my LS coupe (93ejay1)
i'm using a stock LS tranny. yea, i dump it around 2.5k-3k...my friend with an LS coupe, dumps it at 4k and it just spins...
Old May 8, 2005 | 01:59 PM
turboillini11's Avatar
motor mounts....help LIKE MAD for wheel hop.
Old May 8, 2005 | 02:16 PM
itsJDMyo's Avatar
Default Re: (turboillini11)
i have the ES motor mount inserts...should i just get some aftermarket ones? i'm thinking about getting the HAsport. but some people tell me it could also be my suspension, so i don't know yet
Old May 8, 2005 | 02:29 PM
dc2vu's Avatar
is ur car like hella dumped? cuz when mine was i was gettin BAD wheel hop...lifted the car and its almost all better now
Old May 8, 2005 | 02:41 PM
The DX Rex's Avatar
Default Re: (dc2vu)
14.9 is a good time for a coupe
Old May 8, 2005 | 03:49 PM
itsJDMyo's Avatar
Default Re: (dc2vu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2vu &raquo;</TD></TR><TR><TD CLASS="quote">is ur car like hella dumped? cuz when mine was i was gettin BAD wheel hop...lifted the car and its almost all better now</TD></TR></TABLE>
yeah, my car is dumped all the way...about 3". how high did you higher up your car?
Old May 8, 2005 | 05:28 PM
honestly, i dont know the brands of motor mounts, i dont even know a lot about them, but i have a buddy who has a sentra Spec V, and he got motor mounts, and he was just amazed at how well they helped with the launch. sorry i couldnt be of more help.
Old May 8, 2005 | 06:13 PM
dc2vu's Avatar
Default Re: (itsJDMyo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsJDMyo &raquo;</TD></TR><TR><TD CLASS="quote">
yeah, my car is dumped all the way...about 3". how high did you higher up your car?</TD></TR></TABLE>
well mine was dumped all the way too...i lifted it a good 2 - 2.5 inches
this was my own theory on the whole situation...when ur car is hella dumped ur shock has no travel space...and ur bottomed out with the shock casing...so when u launch the suspension, wheels, car, etc bounces cuz ur tires are tryin to get traction, with ur shock not being able to absorb movement it juss kinda bottoms out over and over...think about hittin a hammer on concrete and how it bounces off...thats like ur shockcasing to the top of the suspension thingy (sorry i dont remember names of everything)
lift it, im sure ull get rid of most of the wheel hop...if im wrong...then...uhh...sorry bro hahaha good luck
Old May 8, 2005 | 06:23 PM
92 CIVIC HATCH VX's Avatar
what tires and you can go lower on your psi about 25-22 but hell to drive on after so have a pump or some other to ride on after.
Old May 8, 2005 | 06:25 PM
one reason i was pulling bad 60's is becasue i had shitty tires on top that i was going in to the bleach box with them gettign watter on them and creating bad traction.
Old May 8, 2005 | 06:30 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Finally got 1/4 times for my LS coupe (92 CIVIC HATCH VX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 CIVIC HATCH VX &raquo;</TD></TR><TR><TD CLASS="quote">one reason i was pulling bad 60's is becasue i had shitty tires on top that i was going in to the bleach box with them gettign watter on them and creating bad traction.</TD></TR></TABLE>
I've done the same thing with my brother's mismatched Winter tires (B18C1 EG hatch, dumped) and pulled 2.2x's all night. Dumping the clutch is never the right way to launch. Ever. Feather it out from 3500-4500 depending on how good a driver you are (start low) and be sure to feather the 1-2 shift enough so that your dash doesn't shake itself to pieces. Wheelhop and wheelspin are lost traction and lost time.
If I can pull a 2.25, so can you.
Old May 8, 2005 | 06:33 PM
dc2vu's Avatar
what he said...also when i launch instaed of just dumpin i rev to my desired rpm (around half throttle) then let the clutch out to engaugement with more gas then punch it and let clutch all the way out
Old May 8, 2005 | 06:38 PM
itsJDMyo's Avatar
Default Re: (dc2vu)
i'm on the khumo 411s?? or 711s?? yeah, i was thinking about lowering my tire PSI to about 22, but didn't know if the track had a pump for me to use afterwards, so i just left it at 30 PSI...my next plans are to get new suspension setup (omnipower full coilovers). unless i find out that something else is causing me to wheel hop other then my suspension...
Old May 8, 2005 | 06:52 PM
dc2vu's Avatar
just lift it up and see how it does then
Old May 8, 2005 | 06:56 PM
itsJDMyo's Avatar
Default Re: (dc2vu)
yeah, i'll try that sometime this week
Old May 8, 2005 | 07:21 PM
blackeg's Avatar
on the street i actually drop the clutch at around 3 grand, but feather the gas until i get good traction then punch it.....
14.9 isnt bad in my opinion. i would be happy if i got my ls coupe to do that with some bolt ons. unfortuneatly mine was slow as ***** n/a
wolve
Jun 26, 2008 12:02 PM
itsJDMyo
18
Nov 4, 2005 08:10 AM
Red AEM Civic
Feb 11, 2004 10:15 AM
b18b98
Apr 3, 2003 05:47 AM
yusoslo
Nov 13, 2002 03:12 PM
