.....Broken Valve Cover Bolt.....???
Old May 8, 2005 | 12:17 PM
...emu...'s Avatar
Default .....Broken Valve Cover Bolt.....???
So when I was installing my new valve cover I snapped off one of the bolts that holds it down to the head . Anyways how much should I expect to get this fixed at my local honda dealership? Is this difficult to do or could I fix this myself?
TIA
Old May 8, 2005 | 12:18 PM
jlacoy82's Avatar
71.192.16.183
Default Re: .....Broken Valve Cover Bolt.....??? (milanoturbosi)
Seriously?
Try using the search.
https://honda-tech.com/zerothread?id=567450
Old May 8, 2005 | 12:20 PM
egsleepercivic's Avatar
Is it a Bseries motor ? if it is it is a lot easier than the link above
Old May 8, 2005 | 12:30 PM
biotech0123's Avatar
Default Re: (egsleepercivic)
http://www.slhondaparts.com/br...=true
Part 24, this is a five minute fix, dont waste time taking it to the dealership they will rape you
Old May 8, 2005 | 12:36 PM
^what he said^ I forget what the torque spec is but it not much on the vavle cover bolts get a helms, it will keep you from snapping bolts, I learned the hard way as well
Old May 8, 2005 | 12:40 PM
POE's Avatar
POE
everyone tightens these bolts down WAY to tight. haha i used to be one of those PERSON's... take the valver cover off and access the damage, get a picture of the bolt in the head and post it on here, if u still need help.
Old May 8, 2005 | 01:05 PM
The Internet Tough Guy's Avatar
Default Re: (POE)
7 ft lbs on those bolts
i snapped one too ... been driving around for a couple months now with it like that and no problems. i don't plan on fixing it.
Old May 8, 2005 | 02:53 PM
SOHCejcivic's Avatar
Default Re: (The Internet Tough Guy)
^^same here. i just put a bolt and a washer in the hole so it doesn't srpay oil anywhere. doesn't leak through the vc or at the head
Old May 8, 2005 | 03:09 PM
Default Re: (SOHCejcivic)
yeah i just duct taped the broken bolt there so it stays in place
Old May 8, 2005 | 06:26 PM
HULKHATCH10's Avatar
BRO , FORGET ABOUT GOING TO THE DEALER SHIP . BE READY TO PAY 100 BUCKS FOR A 5 MINUTE JOB...ANY WAYS
GO TO HOME DEPOT, THEY HAVE A LIL TOOL WHICH U DRILL INTO THE BROKEN BOLT AS U START TO DRILL THE THREADS ON THE DRILL TURN THE BOLT COUNTER CLOCKWISE .....WALLLLA BROKEN BOLT OUT IT SECONDS SAVE UR SELF $ 93.00 BUCKS BELIVE ME I WAS THERE ONCE WERE U ARE NOW. GOOD LUCKS .
VISIT SEARS OR HOMEDEPOT
Old May 8, 2005 | 06:41 PM
Kista20's Avatar
ok so what do you do when the threads in the hole get messed up? My buddy took his valve cover off and when he went to put it back on he must not of had one of the bolts right and it messed it up.
Old May 8, 2005 | 06:45 PM
hayabusa160's Avatar
Default Re: .....Broken Valve Cover Bolt.....??? (Kista20)
might have to retap it
Old May 8, 2005 | 07:02 PM
Default Re: .....Broken Valve Cover Bolt.....??? (hayabusa160)
YA , TAPS SETS ARE CHEAP....THATS WAT I DID TO MY FRIENDS BROKEN BOLT..
Alexpbnj
Feb 20, 2011 09:01 PM
czsmola
Apr 25, 2010 05:38 PM
SlowB16si
Jan 28, 2006 02:13 PM
bartek_b
Apr 15, 2003 11:21 AM
illusion
Feb 27, 2002 03:17 PM
