Engine wiring headache!
Old May 7, 2005 | 10:11 AM
crx1racing's Avatar
Default Engine wiring headache!
I swapped out the B15B2 DX engine on my crx with a D16A6 SI and already rewired the ecu, but when I get to the engine plugs, on any of the harnesses the plugs dont match SI or DX. Can someone tell me which wires go where? And please dont send me to rywire.com cause they only sell em not tell you how...
Old May 7, 2005 | 10:43 AM
FalkenSiR's Avatar
Default Re: Engine wiring headache! (crx1racing)
Did you do the MPFI wiring conversion. Wiring at the ecu, like you said, isn't enough to get the car running.
Old May 7, 2005 | 10:45 AM
boosted_hatch_216's Avatar
did you do the extending and get all the right parts for the mpfi swap? and dont you mean the d15b2?
From the EG Forum:
Quote, originally posted by HondaFanatic708 »
So here's the plan,
I'm gonna take 2 complete B16A heads, have a custom 8cyl block forged and a bunch of other custom **** like crank, rods etc. So I wanna drop this BB-series motor in my EG. Anyone got some ideas to go along with this... I think that **** will be crazy, I'll post a pic when I get it done. Stay tuned... Anyone got an S2000 they wouldn't mind pulling the trans and giving me a tracing of the mounting points and shape?
was this guy for real?
Old May 7, 2005 | 10:48 AM
crx1racing's Avatar
Default Re: Engine wiring headache! (fast88std)
yeah, opps i did mean the d15b2, and the only wiring i have done so far is inside the car at the edu, not to the injectors or anything, havent figured that out yet...
Old May 7, 2005 | 10:50 AM
crxgator's Avatar
you need the wiring clips from an Si/HF since they are different by the distributor, you will have to swap the two outter tps wires and wire in the injector resistor box...do a search in the archives for "mpfi" in this forum...you will find a **** ton of info...
Old May 7, 2005 | 10:51 AM
theres one plug you wont use on the d15 harness. but other than that everything should work except the distributor plug. you should have got the with the mpfi swap. have you read an mpfi swap article?
http://www.angelfire.com/d20/h....html
Old May 7, 2005 | 10:56 AM
crx1racing's Avatar
Default Re: Engine wiring headache! (boosted_hatch_216)
I am currently looking up the process, but cant seem to find exactly what i need, i've got both the si and the dx harnesses, but some site say youll have one wire left some say three plugs left and none of them say how to do it...
Old May 7, 2005 | 11:00 AM
no youll have three plugs left but you need two of them for your injector wiring. did you check that link that i posted? that tells you how to do it.
Old May 7, 2005 | 11:04 AM
crx1racing's Avatar
I guess what im looking for is step by step instruction, which i dont expect anybody to tell me, just looking for a website that already has them on there.
Old May 7, 2005 | 11:31 AM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx1racing &raquo;</TD></TR><TR><TD CLASS="quote">I guess what im looking for is step by step instruction, which i dont expect anybody to tell me, just looking for a website that already has them on there.</TD></TR></TABLE>
https://honda-tech.com/zerosearch
Nery hinojosa
Feb 21, 2018 06:56 PM
blue91EF
Mar 3, 2011 08:46 PM
civic ef9
Mar 28, 2008 03:00 PM
oem
Feb 28, 2002 06:08 PM
SedanDX88
Aug 16, 2001 04:08 PM
