Accel 300+ ignition wiring problems
Old May 7, 2005 | 08:47 AM
lohatch's Avatar
Default Accel 300+ ignition wiring problems
i bought an Accel 300+ ignition and external coil second-hand, and didnt recieved the installation instructions with it. there is a sticker on the back that tells you where to wire everything to, but there is a white wire that is supossed to run to the "points/transistor". this is the wire that has me stumped. i dont know if i am supposed to wire it to the ignitor or what??? so if anyone is running one of these and has wired one up, or if anyone has a link to the wiring diagram i would appreciate the help. you can also email me at unsungsohc@hotmail.com. thanks.
Old May 7, 2005 | 09:03 AM
atcrx's Avatar
Default Re: Accel 300+ ignition wiring problems (lohatch)
You will only use the mag pickup wires or the white points wire not both.
Old May 7, 2005 | 03:46 PM
lohatch's Avatar
Default Re: Accel 300+ ignition wiring problems (atcrx)
the mag wires on mine are snipped off, so assuming i am going to use the white points wire. where does it go to ????? or would it be better to not run the white wire and use the other 2 wires??? if i were to do that which wires would they go to on the distributor??
Old May 9, 2005 | 07:04 AM
atcrx's Avatar
yea use the to mag pickup wires. They will connect to one of the pickups in the distributor. But I don't know exactly which ones. It should be the pickup that has 4 point reluctor ring.
Old May 9, 2005 | 09:32 PM
lohatch's Avatar
k i will look into that some more. anybody else out there ever install one of these on a honda/acura????? anybody have a wiring diagram or link to one????? thanks
REDBARON
Sep 24, 2006 07:08 PM
REDBARON
Sep 22, 2006 06:51 PM
SleepnCiViC
16
Oct 30, 2004 11:38 PM
GSRwBOOST
Jan 2, 2002 06:11 AM
