will i be able to...
Old May 6, 2005 | 06:41 PM
idriveadelsol7's Avatar
Default will i be able to...
i need a dril that can drill through my door hindges and the chassis... why? because i stripped the thread trying to align my door correctly. any advice?
Old May 6, 2005 | 07:04 PM
ManBearPig4silly's Avatar
high quality bit, lube it up with wd40, oil, etc..and go slow. then retap it for an oversized bolt.
you are teh done at this point. good luck.
Old May 6, 2005 | 07:38 PM
Default Re: (I4sillypwr)
retap....? new term for me
Old May 6, 2005 | 08:07 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (idriveadelsol7)
you really dont even have to drill the hole out... just go by a tap the same size as the old hole and the same thread pitch as the bolt and retap it. retap means to cut new threads in the metal
Old May 6, 2005 | 08:23 PM
Yeah you can probably get away with just using the same tap size. I wouldnt do it though. It's just a matter of running a drilling through the hole to clean it up and make it bigger. It will take you 30 sec at most and you will have the peace of mind with doing it right.
btw if you oversize it you can make it whatever you want. like if you dont own metric taps
Old May 6, 2005 | 09:20 PM
i just arrived from home depot.... 2 things: i learned what "retapping" is. & they don't have anything in metric. yah~! i only have 2 of the 4 (1 on top hindge ; 1 on bottom hindge) bolts holding my door on. i believe the size is 10mm or 12mm. i want to try 14. it's #25 (the bolt not flange) in the picture below. i need to retap the entrance for that bolt.
http://www.hondaautomotivepart...PANEL
Modified by idriveadelsol7 at 10:36 PM 5/6/2005
Modified by idriveadelsol7 at 10:37 PM 5/6/2005
Old May 6, 2005 | 09:51 PM
The easiest way to do it at this point is to take the hinge bolt to home depot and have them get you an sae bolt, tap and drill bit. drill, tap and install your new bolts. you are done.
ps do a google on tapping or something. they are hardened and break easily if you get rough with them.... much like petite chics.
Old May 6, 2005 | 10:03 PM
they said their bolts are not automotive spec... meaning they will eventually warp or break... what to do?
Old May 6, 2005 | 11:24 PM
go to an auto parts store they will have it
Old May 7, 2005 | 12:00 AM
Flashmn's Avatar
I'd just take the car/door to an automotive shop and have them fix it for few bucks.
Old May 7, 2005 | 04:02 AM
Default Re: (Flashmn)
that's what i was thinking... but autobody people are shardy sometimes... they might just glue the bolt in lol. it's a simple task i think i can handle.
Old May 7, 2005 | 11:32 AM
funvtec's Avatar
it would be cooler to just weld your doors shut and jump through the window al the time
dukes of hazard style
Old May 7, 2005 | 12:07 PM
RCautoworks's Avatar
Default Re: (funvtec)
What bites are better, carbide, or Titanium?
Modified by 90blackcrx at 3:17 PM 5/7/2005
Old May 7, 2005 | 02:56 PM
i might have to... i need to take it to an autobody for certain now. i can't even retap it because it's so messed up. i hope they have bolts there about an inch in diameter.
Old May 7, 2005 | 05:31 PM
swanny's Avatar
lol, holy **** kid what did you do? take pics.
Old May 7, 2005 | 08:51 PM
Default Re: (swanny)
when i get my digital camera... ah. nothing to bad just increased the thread size a bit.
Old May 8, 2005 | 10:18 AM
bigTom's Avatar
Default Re: (90blackcrx)
carbide is meant for hard metals and carbide tipped drills are for masonary work... tin (or titanium as u called is) is not a titanium drill but just a coating... all u need for ur purpose is just a good drill... pretty much dont buy the chinese crap for $.50
Old May 8, 2005 | 09:09 PM
wish me luck people. autobody i go ... hopefully it's fixable.
jinxd12
17
Feb 23, 2011 02:59 PM
Fatty Wagovan
12
Oct 13, 2009 04:11 AM
Luckywhiteboi
Mar 6, 2009 03:58 AM
TurboEM1
Sep 29, 2006 12:27 PM
