Moroso Drag Oil Pan -100 dollars / oil pickup - 20 dollars
Old May 6, 2005 | 08:30 AM
dasher's Avatar
Default Moroso Drag Oil Pan -100 dollars / oil pickup - 20 dollars
SOLD////////////////////////////////////////////////////
Moroso / MOR 20901 Acura Integra 94-98 1.8L Vtec/non vtec compatible
Perfect for turbo cars needing the oil return line fitting!
100 + Shipping For pan
20 + shipping for MOR-24010 for oil pickup which works with this pan
Getting rid of oil pan because I went with the new moroso auto-x pan instead.
Selling this cheap because the drain bolt threading is stripped. You can still screw in the bolt but it doesn't seal tight and will leak slowly without the use of honda-bond. I drove around with it fine with some grey hondabond for thousands of miles. Another option would be to simply cut off the old oil drain bung and pay 40 dollars to a local welder to have another one welded on.
There is an extra bung on the back of the pan for an oil temp sender.
This is a shot of the bottom where I used some Devcon Liquid Aluminum(Good as Aluminum- Not JB weld) to repair a scratch(As you can see from the above pick it did not go through the pan).
Paypal or M/o ok....
Paypal verified with many confirmed sells @ paypal username mkirsch@cfl.rr.com.
Some old vouches are listed in sig, got tired of listing all the new ones....
Modified by dasher at 11:46 PM 5/8/2005
Old May 6, 2005 | 09:10 AM
SHystrdyGSRtdy's Avatar
Default Re: Moroso Drag Oil Pan -100 dollars / oil pickup - 20 dollars (dasher)
damn... i have a 99
Modified by SHystrdyGSRtdy at 10:47 AM 5/6/2005
Old May 6, 2005 | 10:14 AM
dasher's Avatar
SOLD//////////////
Modified by dasher at 11:47 PM 5/8/2005
Old May 6, 2005 | 10:32 AM
White Smoke's Avatar
i my honda
Global Mod
So only the drain bung is striped? Do you have a pic of that?
Old May 6, 2005 | 10:59 AM
Default Re: Moroso Drag Oil Pan -100 dollars / oil pickup - 20 dollars (White Smoke)
i asked moroso about the pan... if they say it will fit my car.. i still want it
Old May 6, 2005 | 11:06 AM
dasher's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">So only the drain bung is striped? Do you have a pic of that?</TD></TR></TABLE>
The drain bung is made of ALuminum, the Drain bolt steel ... just the bung is stripped--- This is a drawback of this pan, you have to be carefull when tightening the bolt ... I wasn't.
Old May 6, 2005 | 03:41 PM
dasher's Avatar
Old May 7, 2005 | 09:04 AM
dasher's Avatar
Oil pan can be useed for B18b1, b18c1, b18c5 cars but the oil pickup is for vtec cars only! Can be purchased seperately.
Old May 7, 2005 | 09:31 AM
dasher's Avatar
Sale pending... damn that was quick.
Old May 7, 2005 | 11:24 AM
JDMH22HATCH's Avatar
Awesome deal.
Old May 8, 2005 | 07:47 PM
dasher's Avatar
Default Re: Moroso Drag Oil Pan -100 dollars / oil pickup - 20 dollars (JDMH22HATCH)
Sold....
ccjustin
Apr 27, 2006 02:53 AM
Stewie
Welding / Fabrication
Nov 9, 2005 08:38 AM
fandango
Jan 20, 2005 06:20 PM
Peter K
Aug 25, 2001 08:35 PM
