si cluster..
Old May 5, 2005 | 11:56 PM
trick_db's Avatar
Default si cluster..
heylo..how do you fix your gas meter..is broken..do you noe how?
Old May 5, 2005 | 11:59 PM
Cuong-nutz's Avatar
Default Re: si cluster.. (trickek9)
when you know you just poured a full tank of gas and the gauge reads empty still.
it's possible that the fuel sending unit went bad. not sure how you test to see if your guage is bad or not, but bump for you
Old May 6, 2005 | 12:11 AM
taney's Avatar
borrow someone's dx cluster and check it .. if it is the cluster .. you mind as well have more luck buying a new cluster than replacing the fuel gauge as far as i know .. =\
Old May 6, 2005 | 01:27 AM
BlueIntegraBoy's Avatar
Default Re: (taney)
The fuel gauge portion is a lot cheaper from Honda than to buy a whole cluster.
Old May 6, 2005 | 03:27 AM
Frozen E's Avatar
H-T White Ops
Like $23 or something like that for the temp/fuel cluster from honda. I was suprised as hell. I was expecting like $200 or something when I first went to look it up.
Old May 6, 2005 | 08:08 AM
taney's Avatar
o damn .. $23?? yeah i expected an insane number .. cause the spedometer is insame .. like $300 .. you can get a cluster for $150 .. lol ..
MTarry
11
Jan 15, 2013 06:46 PM
JDM_WHR
10
Jun 7, 2010 08:50 AM
tifosi
Jul 11, 2008 10:13 AM
NsX_CrX
May 30, 2005 04:55 PM
cheezemaster
Sep 19, 2001 09:10 AM
