obd1 d15b fuel cutting @ 5000rpm (went through 10+ pages of searches)
Old May 5, 2005 | 03:27 PM
mengy007's Avatar
Default obd1 d15b fuel cutting @ 5000rpm (went through 10+ pages of searches)
Checked all sensor plugs twice, they are in the correct places
Tried different ecu's
Checked continuity of vtec solenoid / oil pressure switch / MAP sensor wires (still have others to check)
pulls hard until 5krpm sometimes 5.5k then seems like fuel is being cut off
I can't find the service plug to check the ecu codes... Is there another way to check the code?
Engine check light is on when car is running
I'm out of clues... help?
Old May 5, 2005 | 03:28 PM
Luserkid's Avatar
Default Re: obd1 d15b fuel cutting @ 5000rpm (mengy007)
Your in limp mode, heres how to check ecu codes:
https://honda-tech.com/zerothread?id=1171263
Old May 5, 2005 | 03:36 PM
mengy007's Avatar
Default Re: obd1 d15b fuel cutting @ 5000rpm (Luserkid)
I know how to check the ecu codes like that, I think the previous owner cut it out or hid it somewhere, because I used to have a 93 hatch and I've checked the ecu codes before I just can't find the service plug anywhere on this particular civic
Is there another way of checking it?
Old May 5, 2005 | 03:38 PM
EK k kay's Avatar
Take it to autozone or something and have them use the obd diagnostic tool thing.
Old May 5, 2005 | 03:47 PM
mengy007's Avatar
Default Re: obd1 d15b fuel cutting @ 5000rpm (chowmien)
hmm how much would a session cost?
Old May 5, 2005 | 03:50 PM
EK k kay's Avatar
I'm sure they will do it for free since they do compression checks for free. Call them up.
Old May 5, 2005 | 04:48 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien &raquo;</TD></TR><TR><TD CLASS="quote">Take it to autozone or something and have them use the obd diagnostic tool thing. </TD></TR></TABLE>
You mean the one that plugs into the OBD2 cars? That probably won't work...
Keep looking for the connector, Some cars have it plugged into a dummy connector, or taped to the wire harness. If all else fails, just ground the appropriate wire on the ecu "manually".
Old May 5, 2005 | 06:19 PM
mengy007's Avatar
Default Re: obd1 d15b fuel cutting @ 5000rpm (drdisco69)
Which wire would I need to ground on the ecu? I can do that... the wires are supposed to be white/black and red/black... there are 3 plugs that are 2 wires but none of them are those colors and they all seemed to be pluged into something
Old May 5, 2005 | 06:22 PM
sadangryboi's Avatar
change ur fuel pump
happened to another guy on here when he did a ls swap into his eg
Modified by sadangryboi at 7:21 AM 5/6/2005
Old May 6, 2005 | 02:37 PM
mengy007's Avatar
Default Re: obd1 d15b fuel cutting @ 5000rpm (sadangryboi)
Could you point me towards the thread if it's still here
Derrick_12341
10
May 21, 2018 07:41 PM
gtownjoe
Jan 13, 2012 02:32 PM
e jay one
Jun 12, 2007 04:04 PM
sgi
Feb 7, 2003 03:24 PM
civicsport
Dec 26, 2002 09:41 AM
