my cooling fan not coming on ? already check fuse !?
Old May 4, 2005 | 08:34 PM
efboy's Avatar
Default my cooling fan not coming on ? already check fuse !?
yes like the title said... the fan don't turn on?? i already check the fuse
it's like the car stay in good temp , but when i let the car sit ..all of the suddenly
******* coolant is all boiling like crazy.. so duno what i should do
make a switch or just check for other things !??
Old May 4, 2005 | 08:36 PM
1boostedhybrid's Avatar
Default Re: my cooling fan not coming on ? already check fuse !? (efboy)
Check your thermoswitch. It's located by the thermostat. It's either that or the wiring on the plug.
Old May 4, 2005 | 08:42 PM
efboy's Avatar
Default Re: my cooling fan not coming on ? already check fuse !? (1boostedhybrid)
located by it?? what does it lok liek??
Old May 4, 2005 | 10:44 PM
RCautoworks's Avatar
https://honda-tech.com/zerothread?id=1233217
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1boostedhybrid &raquo;</TD></TR><TR><TD CLASS="quote">Check your thermoswitch. It's located by the thermostat. It's either that or the wiring on the plug.</TD></TR></TABLE>
Stop telling him to look for things that do not exist in his car. There is a radiator fan sensor on the back of the block no switch near the thermostat.
Old May 4, 2005 | 10:53 PM
FOMULA91's Avatar
Default Re: my cooling fan not coming on ? already check fuse !? (90blackcrx)
DAM, I have a switch for my fan.
Old May 4, 2005 | 11:05 PM
Default Re: my cooling fan not coming on ? already check fuse !? (FOMULA91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOMULA91 &raquo;</TD></TR><TR><TD CLASS="quote">DAM, I have a switch for my fan. </TD></TR></TABLE>
Are you talking about a thermostat switch, or a manual switch ?
Old May 4, 2005 | 11:35 PM
FOMULA91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Are you talking about a thermostat switch, or a manual switch ?</TD></TR></TABLE>
The switch next to my steering wheel.
Old May 5, 2005 | 01:58 AM
whiteknightef's Avatar
guys you need to listen to the man when he says switch in the back of the block. i hae had 2 go bad. if the car is at idle and the fan is not coming on then that IS THE PROBLEM. there should be a two prong sensor switch right above the oil filter undernieth the intake manifold (if you have a stock d-series engine).
Old May 5, 2005 | 02:32 AM
jc836's Avatar
Depending on which engine you have, the Thermoswitch is located near the Oil FIlteron a D16a6. It has 2 wires on a plug. You can jumper the plug to see if the fan comes on. It is also possible to test the fan by umplugging it and running a pair of jumpers directly to the battery.
nothing_shocking
14
May 13, 2010 04:40 PM
ctrld-kaos
Dec 7, 2006 05:22 AM
crxhftosi
Feb 22, 2005 07:53 AM
gobblebox59
Aug 29, 2004 02:04 PM
turboD16
Nov 24, 2002 03:18 PM
