CLUTCH won't engage... help?
Old May 4, 2005 | 07:57 PM
screen_name's Avatar
Default CLUTCH won't engage... help?
okay so i finally got my swap in,
i have a new exedy clutch on it and the pressure plate that came with the kit. everything worked fine for like a mile..
except the clutch pedal felt way too loose the whole time, anywho i drove for a mile it shifted fine and everything then all of the sudden it revved but didnt go anywhere... i tried putting it in gear but nothing happens..
when i put it in first it smoothy goes in no grind or anything, but i let the clutch pedal out and start to add some gas like normal and the car doesnt move anywhere, just revs and the mph goes up but the car aint moving..
i checked to see if the slave cylinder is moving and it is.. it pushes the fork in and out like normal but the pedal feels loose... i already did a line bleed still feels weak...
Old May 4, 2005 | 08:04 PM
7psiCivic's Avatar
Default Re: CLUTCH won't engage... help? (LB562)
I had the exact same problem with my 2000 EX. If the speedo is rising but the car isn't moving, one or both of the CV axles have probably popped out of the tranny. I had to take the wheels off undo the 32mm nut, then pull the axle away from the tranny, then shove it back in. If it does it again, you might need to replace the clip on the end of the CV. Hope this helps......Let me know
Ej8_KiD
Mar 4, 2010 09:54 PM
all-mtr-teg
Sep 17, 2007 09:28 PM
vtec69
20
May 4, 2005 05:48 PM
RotiEatter
Oct 25, 2004 07:04 PM
jonoknut
Dec 26, 2002 11:56 AM
