d15b, what aftermarket rods?
Old May 4, 2005 | 06:43 PM
phatrick2332's Avatar
Default d15b, what aftermarket rods?
What rods work in the d15b? I 'think' that the d15b has the same journal size as the d16 and the rod length of a d15 correct? So what the hell will fit in them.
Old May 4, 2005 | 06:45 PM
TorinRage's Avatar
Default Re: d15b, what aftermarket rods? (phatrick2332)
bump u pat
Old May 5, 2005 | 01:59 AM
TorinRage's Avatar
Default Re: d15b, what aftermarket rods? (TorinRage)
i ponder this to
Old May 5, 2005 | 03:16 AM
blo2k1's Avatar
i have been trying to figure this out for a while to the d15b vtec rod # is 13210-PM6-000 same as z6 Rods both 137mm, but have different journals i know none of the aftermarket companys make them crower eagle ect
but i heard of people using after market ls rods and machining them??? any info would be good!! and someone that knows there stuff not guessing
brent
Old May 5, 2005 | 07:07 AM
Ls rods have the same big end journal size as the d16, so they are to big for the d15, but the length is the same.
Bump for some info.
Old May 5, 2005 | 08:16 AM
Brownjd's Avatar
Default Re: (phatrick2332)
hmmm... so you might have to use a z6 crank to use aftermarket rods.
Old May 5, 2005 | 08:58 AM
Default Re: (Brownjd)
But if the d15b is just like the other d15's then the main journals are smaller than the d16, but im not sure. It could possibly have the larger mains and rod journals like the d16 but just have the shorter rod like that of the d15.
I know that somebody here on HT has to have some kind of experience with these things.
Old May 5, 2005 | 10:07 AM
senpai's Avatar
you measure the d15, someone measure the d16, and we can figure it out.
Old May 5, 2005 | 10:49 AM
Brownjd's Avatar
Default Re: (senpai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by senpai &raquo;</TD></TR><TR><TD CLASS="quote">you measure the d15, someone measure the d16, and we can figure it out.</TD></TR></TABLE>
i didn't know we could post something that makes this much sense
Old May 5, 2005 | 12:02 PM
senpai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brownjd &raquo;</TD></TR><TR><TD CLASS="quote">
i didn't know we could post something that makes this much sense </TD></TR></TABLE>
I'm trying hard today.
I got a6 rods sitting in a box.
Old May 5, 2005 | 12:22 PM
slywfbpsi's Avatar
This has been discussed many times. Just use z6 rods in it.
Old May 5, 2005 | 12:38 PM
TorinRage's Avatar
Default Re: (slywfbpsi)
hrmmm so use z6 rods eh
Kendall
14
Mar 1, 2023 07:16 PM
bzyq2001
Dec 12, 2007 02:53 PM
NINJASPY
Jan 23, 2005 03:25 PM
b16sellout
Nov 9, 2004 08:47 PM
hackish
Sep 2, 2003 05:06 PM
