Thinking about the mani for a DIY project
Im thinking of making this mani for a DIY project for my sohc and also because I bought a welder, find it entertaining to melt 2 pieces of metal together and dont like the thought of paying someone to do something I can do... Onward...
This is a mani I believe legendboy on here made...
This is the way I'd like to do it...
Would the angle the wastegate is placed at that location matter (planning on keeping a/c so i'd have to angle it more for my tial to claer the a/c condensor)?In addition to changing the WG placement (if not it would basically be the same thing as running a drag mani, which I already have and hence would be wasting my time), I was thinking that I would attempt to basically run a 45* angle for runner 2 and 3 and try to merge it to the runners on 1 and 4 for a better transition. I'd like some feedback on this idea....
Also the welder I have is a Lincoln Electric Weld Pak 100HD with the mig conversion kit... Any of you who have had experience with this machine I'd also like to hear your thoughts on completing this project with this machine...
TIA
TIA
bump...
Are there any downsides to using mild steel as aposed to stainless steel? Which gas should I use for mild steel and which should I use for ss if i decided to go that route? I was thinking of using schedule 10, would that be fine or should I use something else? Any help or suggestions would be appreciated!
TIA
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted96EK »</TD></TR><TR><TD CLASS="quote">bump...
TIA</TD></TR></TABLE>
dunno about the schedule part but mild steel rusts for one and it takes less heat then s/s. i also believe that mild steel is more likely to crack.
Yeah I know mild steel rusts... but im not really concerned about rust because I plan on ahving it coated... I do need to know if schedule 10 is good enough.... and what gas I should use... If ss is better than mild for this I have no problems going with ss...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx »</TD></TR><TR><TD CLASS="quote">Mild steel will be fine. Gas you want to use co2/argon. The hardest part about the whole project will be cutting everything to fit good.</TD></TR></TABLE>
Yep mild steel will work fine. As far as the cuts go, they don't look that bad. The 4 outer tubes look almost the same, but just reversed. And the 2 bottom ones going to the collector look the same as the outer ones, just turned upside down.
the larger picture you posted has a poor wastegate flange location, chances are you might see some creep from that.
better off putting it where they merge at the flange like the lower pic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted96EK »</TD></TR><TR><TD CLASS="quote">Yeah I know mild steel rusts... but im not really concerned about rust because I plan on ahving it coated... I do need to know if schedule 10 is good enough.... </TD></TR></TABLE>
I doubt they even make 1.5" weld els in sch10 mild.
sched 10 is too thin.
mild steel is LESS likely to crack than stainless.
i would stick to the sched 40 weld el's personally, that way you know there's lots of meat to support your weld as well as the 20lbs or so of your turbo.
also brace the turbo off the block.
I made a log manifold. Before you weld the runners together, squish the ends so the runners are more matched to the oval flange head flange. Do this BEFORE welding the runners together or it will put a lot of stress on the welds. Good luck!
sch 10 should be fine and is thick enough. All my manifolds are made out of this and never have cracked. Sch. 40 is just way to thick. Believe me you will be more happy going with sch. 10 and once you get it you will realize it's way thick enough unless you are supporting some CRAZY weight. (twin turbo or somthing in this area)
spoolin turbo s
Nov 4, 2008 05:59 PM
