Need Uberdata help: running lean only 20% of time
This just started hapening recently. I'm using uberdata and 450cc's. So when I'm driving, my lambda air/fuel guauge reads super lean in closed loop, then it will go to normal again when I step on it enough to activate open loop, then back to super lean after I ease up on throttle. This happens even when I deactivate open loop and run only in closed loop. I'm thinking bad O2 sensor, or maybe fuel settings in in Uberdata are too low to keep injectors open? Usually heppens when cruising in 5th at very low throttle. Anyone have similar problems? After a few minutes it will run fine again...
Thanks
Modified by pipes at 7:28 PM 5/4/2005
Thanks
do you have open loop / closed loop backwards? open loop = WOT/boost
i havent been in FI for a while, is uberdata real popular now?
sorry yes, allow me to fix post...
To answer your question, I havent been online much but Uberdata seems to be getting big for engine management.
Max500
Engine Management and Tuning
12
Oct 16, 2011 09:12 AM
underpressure02
Sep 22, 2004 12:34 PM
