low idle after replacing cap and rotor
Old May 4, 2005 | 09:20 AM
Thirty-Nine's Avatar
Default low idle after replacing cap and rotor
I replaced the cap and rotor with OEM parts on my wife's 98 EX.
She said that now it seems to idle lower than usual (dips under 500 rpm). It doesn't die, though.
Any thoughts on this? Anyone else have this experience?
Old May 4, 2005 | 09:59 AM
Teinz's Avatar
very comon on honda check your air hoses also somtimes you might accidently knock it loose. Plus all wires correct?
Old May 4, 2005 | 10:17 AM
Default Re: (Teinz)
I did not replace the wires; there wasn't any noticabe corrosion or wear on them.
Old May 4, 2005 | 11:09 AM
gftgrill's Avatar
sounds like you might have a couple of wires switched
Old May 4, 2005 | 12:16 PM
tominos's Avatar
Default Re: low idle after replacing cap and rotor (Sushiboy)
does the car run rough or is it smooth but the idle is just lower. you can adjust the idle speed by turning the screw on the throttle body. the idle speed adjustment screw. use a flat head.
Old May 4, 2005 | 06:56 PM
Default Re: (gftgrill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gftgrill &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you might have a couple of wires switched</TD></TR></TABLE>
I'm 99% sure I didn't because I labled the cap to correspond with the wires. I'll triple check, though.
Thanks for the advice.
reureubear
Nov 22, 2015 03:34 PM
DEPintheCurve
Jul 18, 2012 03:17 PM
bizmackus
Feb 16, 2007 06:34 PM
epoch707
Mar 17, 2006 03:11 PM
GreenEX
Jan 23, 2004 08:47 PM
