Tacho problems, need help...
Old Feb 2, 2002 | 05:55 PM
Dr. Gonzo's Avatar
Default Tacho problems, need help...
Ok here is my situation: (D16Z6)
Three of days ago I my tachometer started jumping around when I take it above 3500 rpm. So two days ago I pulled off the distributer cap and found oil on the outer bottom edge where the cap and distbuter meet. I cleaned it with a paper towl and put it back on. The tach didn't stop doing it, but then it took about 4500 rpm to make it jump. So yesterday, I pulled the whole damn distributer off and sprayed it down, including the inside with contact cleaner. I also went to Honda and bought another seal for the distributer because I figured that's what was causing oil to get in there. So I take it out for a drive and it went away!!! Today,
it started up again. I want to say that it's oil, but I replaced the seal. Does anyone have any sugestions on what I should do? Ever heard of this before? Anyone?
Old Feb 2, 2002 | 07:22 PM
Dr. Gonzo's Avatar
Default Re: Tacho problems, need help... (93GBlackDelSol)
anyone??????
Old Feb 3, 2002 | 09:58 AM
SUis1's Avatar
Default Re: Tacho problems, need help... (D16_VTEC)
I had a similiar probelm with my 92 Si. It turned out to be the ignition control module in the distibuter...I didn't have the oil probelm and I got a check engine light and a code 15.........$100 bucks from Honda.
chasenpaper
Honda Civic (2006 - 2015)
10
Aug 29, 2010 04:24 PM
messeduprex
Mar 31, 2007 03:10 PM
BadEH2
Nov 15, 2004 02:51 PM
Nizzy
Jan 13, 2003 09:22 PM
Nizzy
Jan 13, 2003 06:51 AM
