looking for more power sohc Zc isnt cutting it
first of all it's vtec. second, if you want more power, dont just get rid of the sohc, throw together a junkyard/custom turbo kit and boost the bitch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1989hf »</TD></TR><TR><TD CLASS="quote">need some suggestions on what to swap to i want dohc v-tech that can withstand 10-18 psi boost </TD></TR></TABLE>
haha
haha
......what are your actual goals.
horsepower and torque.
then decide what engine is capable of those goals.
you want boost? try a lower compression engine. ie: not a high compression vtec. unless you want to rape your piggy bank with a steel ***** in engine internals.
you dont need us for this.
search.
search.
why not turbo the motor you have? it can handle 200hp+ with good tuning. you dont always have to swap to have more power. plus the turbo kit would be cheaper than swapping if you put it together yourself
Guest
Posts: n/a
Learn more about cars, before you post
9db85
Dec 21, 2006 05:51 PM
