I I have a chipped ecu and remove the chip.....
Old May 3, 2005 | 05:41 PM
hotimportcrx's Avatar
Default I I have a chipped ecu and remove the chip.....
if i have a ecu with a chipm that was set up for all motor...if i remove the chip will it restore to stock settings.....or will i have to place a stock chip there someone please helppp...or if u wanna trade for my all motor b16 ecu obd0 for a stock one let me know...(i went boost and all motor ecu runs like **** on turbod car)...will provide aditional power
Old May 3, 2005 | 05:46 PM
ILLCRXSI's Avatar
rechip the one you have. if you are planning on using the stock ecu with the turbo, let me know when your shell is for sale. just leave the motor and stuff in it though the trans will still be good.
Old May 3, 2005 | 05:50 PM
HamiltonRex's Avatar
Default Re: I I have a chipped ecu and remove the chip..... (HondaDelsol17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaDelsol17 &raquo;</TD></TR><TR><TD CLASS="quote">if i have a ecu with a chipm that was set up for all motor...if i remove the chip will it restore to stock settings.....or will i have to place a stock chip there someone please helppp...or if u wanna trade for my all motor b16 ecu obd0 for a stock one let me know...(i went boost and all motor ecu runs like **** on turbod car)...will provide aditional power</TD></TR></TABLE>
Dont run a all motor chip on a turbo'd car. It will blow up in less then 500miles.
I know on obd1 ECU's to return to stock maps, you just cut the J1 jumper.
Old May 3, 2005 | 05:57 PM
Default Re: I I have a chipped ecu and remove the chip..... (HamiltonRex)
how do i go about re programming the chip
Old May 3, 2005 | 06:15 PM
BlueShadow's Avatar
if you are OBD 0 then use turboedit to program a new chip. If you dont know what that is, then you should do a search for turboedit or H-T member xenocron. I believe xenocron is up in your area somewhere, and maybe he can help you.
cghorr01
Engine Management and Tuning
Feb 2, 2010 08:32 AM
so simple
Apr 12, 2009 08:31 PM
95excoupe
Feb 25, 2005 05:25 PM
bearboy80
20
Sep 17, 2003 02:20 PM
