changing the exhaust housing on a garrett t-3 42/.48 a/r
Old May 3, 2005 | 08:40 AM
redlseg's Avatar
Default changing the exhaust housing on a garrett t-3 42/.48 a/r
if i were to change the exhaust housing to a .63 a/r, would i be able to reach the red line with out losing boost at a lower rpm? also when i change it out do i have to change the blade also? thanx in advance
Old May 3, 2005 | 10:31 AM
redlseg's Avatar
Default Re: changing the exhaust housing on a garrett t-3 42/.48 a/r (95eg6turbo)
back ttt
Old May 3, 2005 | 11:40 AM
redlseg's Avatar
can someone help me out
Old May 3, 2005 | 11:52 AM
tgreaves's Avatar
Default Re: changing the exhaust housing on a garrett t-3 42/.48 a/r (95gsrhatch)
I would look into a higher flowing compressor section.. Talk to Stan(flamenco-t) about this..
Old May 3, 2005 | 03:46 PM
redlseg's Avatar
Default Re: changing the exhaust housing on a garrett t-3 42/.48 a/r (tgreaves)
will the turbo as it sits with the 42/.48 a/r reach at least 7500k rpm without losing boost?
Old May 3, 2005 | 03:51 PM
92civicb18b1's Avatar
you wont loose boost...
you should be fine depending on how much you're boosting. It shouild hold 8 psi to 7500 rpm.
If you're willing to swap housings, get a bigger intake side....it will be much more effective and you won't add much lag compared to the exhuast side.
Old May 3, 2005 | 04:02 PM
redlseg's Avatar
Default Re: changing the exhaust housing on a garrett t-3 42/.48 a/r (92civicb18b1)
i plan on just boosting up to 10psi on my gsr. what size compressor housing should i get?
Old May 3, 2005 | 04:32 PM
redlseg's Avatar
would a 60 intake housing fit?
Old May 3, 2005 | 07:16 PM
redlseg's Avatar
bump
Old May 4, 2005 | 02:20 AM
yes, and a 60/48 would be a nice sized turbo.
hialeahzbg
May 6, 2007 02:45 PM
BOOSTEDCIVICD16
Jan 29, 2004 04:40 PM
bluedelsol
Jun 14, 2003 11:37 AM
Spoold_R
Apr 10, 2003 12:19 PM
mrblur
Oct 18, 2002 10:57 PM
