Any turbo guys switch from a light flywheel back to stock ?
Old May 2, 2005 | 04:36 PM
salt's Avatar
Default Any turbo guys switch from a light flywheel back to stock ?
I'm having trouble with my 60' but its mostly my fault. I haven't fully loaded my 2 step to launch with more boost, and its hard to tell when to shift into second. On my data logs I always shift into second before the 60'. Is this normal on a B16 tranny with 24.5in slicks ?
I have a 7.5lb fidanza flywheel on there now and I am thinking of putting the stock one back on to make up for my lack of skill. Has any one else had similar experiences ?
gsr 81mm block 8.7:1
gt30r turbo @1 bar
2500lb car
Old May 2, 2005 | 04:41 PM
hondaguyef's Avatar
Default Re: Any turbo guys switch from a light flywheel back to stock ? (salt)
I was having the same problem. I switched back to 22's and the 60' problem is gone and I pass the line at a good RPM now. Since you have the B16 tranny you may not be able to go w/ much shorter of a tire. I had to play alot w/ RPM before I finally got it right. What 2step are you using and are you building boost on the line?
Phil
Old May 2, 2005 | 04:57 PM
salt's Avatar
Default Re: Any turbo guys switch from a light flywheel back to stock ? (hondaguyef)
I am using the AEM and I set the Ignition cut @ 7400 and fuel cut @ 7600. It lets some fuel get by and since the ignition is also getting retarded it fires it late and it is burning as it leaves.
I have a set of 22" slicks I dont use because I get about the same 60' but I get slower traps and ET's.
Old May 2, 2005 | 05:03 PM
hondaguyef's Avatar
Seat time may be your enemy then. I was having a hell of a time on the 24.5's so, I went back to the 22's for a while. Now that I can build 5psi on the line, I'm not sure how they are going to perform. We'll see this weekend. Good luck to you.
Phil
Old May 3, 2005 | 06:49 AM
salt's Avatar
good luck on some new best times, our cars have pretty simlar times. Maybe I'll try the old flywheel next time I have it apart. I'm not worried about loosing 5 HP from a hevier flywheel I'd really like to go from a 2.0 60' to a 1.7 like the SRT4 who keeps beating me has.
SeDA(9)n
Nov 3, 2008 11:32 PM
jordanitr
Jan 22, 2007 04:06 AM
yellowturbo
Dec 20, 2004 08:59 PM
jaxx4k
Aug 3, 2004 06:52 AM
93B17A
Dec 17, 2001 07:26 AM
