***The End All Del Sol Roll Cage/Bar Thread***
Post up any information, pictures, and questions that you have on this topic please. Anything that can help would be appreciated.
search bro. here are some i found
https://honda-tech.com/zerothread?id=1231972
https://honda-tech.com/zerothread?id=988196
https://honda-tech.com/zerothread?id=914361
https://honda-tech.com/zerothread?id=851542
https://honda-tech.com/zerothread?id=804845
https://honda-tech.com/zerothread?id=713843
https://honda-tech.com/zerothread?id=264156
https://honda-tech.com/zerothread?id=407622
I checked all those links and to be honest, are any of those gonna pass inspection?
Keep this thread alive cause there's gotta be somebody out there with a cage that can pass inspection.
I could'nt find it........ http://www.ioportracing.com/faq/APapplications.htm
EDIT: Just called 'em and I quote " No, we do not make one for the Del Sol and we don't know of anybody that does." Sounded like they've gotten this call quite a bit.
I am not asking a direct question, I wanted to create a refrence for others...thanks for the classic dumb **** "use the search button" remark. Autopower doesn't make one for the sol.
I had a 4pt Cusco Roll Bar in my old one...
pictures can be found on this link
http://www.mackeydesigns.com/soless/
So is that legit in any form of racing? It looks nice...custom? I have a sparco speed seat and it is a fixed back so I need something to sit close enough to the ceiling.
I don't know, you'd have to have it checked out..
and no its not custom, made for an EG2 CRX Del Sol in japan.
Made to fit stock seats though... I'm pretty sure...
I was told it was FIA approved... not sure that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mospeed »</TD></TR><TR><TD CLASS="quote">I was told it was FIA approved... not sure that helps.</TD></TR></TABLE>
FIA approved is not legal in the us for any santionced roading series. which excludes most of the cusco and saftey 21 crap. A custome roll cage for a del sol will probaly cost some where around 1200 depending on who and how much you want done to it. To be leagal for most us road racing series, the cage down tubes will have to go into the trunk some how, usually through the back window, however I have seen one cage in a del sol that passed tech that had the tubes routed into trunk without going trough the back window.
that's the cusco bar, correct? no, it's not legal for any type of racing. the tubing is too small.
i think the person that passed without having to go through the rear window is adictionbass.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">if you're serious about it, you'd be better off with a custom cage.
