Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Old Mar 25, 2015, 11:00 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Will a totally dead battery take a jump start?
Old May 2, 2005 | 06:53 AM
speedracer33's Avatar
Default Will a totally dead battery take a jump start?
I finally got the rotors in for the Civic and swapped them on this weekend. However, when I went to start the car I got another surprise. I expected the battery to be stone dead, which is was. However, the surprise is that it wouldn't start even with the jumper box (fully charged).
It turns over a bit, but not the painfully slow turnover you get with an almost dead battery. It's just not enough to start the car. I tried using jumper cables and a spare tractor battery, but that didn't work either. I also hooked up a battery charger to it, and it won't take a charge.
So the question is, is the problem beyond just the battery, or is it simply the fact that a completely stone dead battery can't be jumped? Thoughts?
Old May 2, 2005 | 06:56 AM
WRXRacer111's Avatar
Default Re: Will a totally dead battery take a jump start? (speedracer33)
Yes, if the battery sits discharged for a "while" (i have no idea how long it actually is, just that i've let them sit "long enough"), the battery dies beyond repair; you can get it tested at an auto parts store, it'll probably show really low cranking amps on the tester. Don't know exactly what causes it/why it does that, just that it happens and you're generally stuck with replacing the battery.
Old May 2, 2005 | 07:30 AM
Todd Reid's Avatar
Default Re: Will a totally dead battery take a jump start? (WRXRacer111)
hey matt!
really really dead batteries are hard to jumpstart.
you can try using Moby with good thick jumper cables; have a helper rev Moby up to about 2000 to 3000 rpm and hold it there.
at the same time, crank the civic. it'll probably start that way...
todd
Old May 2, 2005 | 07:33 AM
rustyhatch's Avatar
i had a 77 chevy truck with a voltage leak i never found. it would go for weeks without doing it and then do it for a solid week. it would completely drain the battery in as little as 6 hours. dead. flatlined. on a cheap no name battery, it never recovered. on a sears diehard gold battery, i could disconnect the positive terminal hook the jumper cables to it and start it up and it would have it recharged in about an hour. did it many times. it all depends on the battery in my experience.
chevy wiring
diehard batteries
Old May 2, 2005 | 07:52 AM
Default Re: Will a totally dead battery take a jump start? (rustyhatch)
Hmmm, I'm going to order a new one in that case, because regardless of whether there are other problems, if it won't take a charge it's useless. I thought about trying to jump it with the Lude or the Jeep, but I can't jump it with the car nosed into the garage so I would have to push it out. The problem is that my driveway slopes downwards, so if I couldn't start it, I wouldn't be able to push it back in.
Thanks for the advice, I'm feeling more confident that it's just the battery.
Old May 2, 2005 | 08:57 AM
FlyZlow's Avatar
Did you try a deep cycle charge? Before a race weekend, I usually put my battery on a 2 amp charge for 48 hours. If that doesn't charge it, nothing will. If you use the method Todd suggested, it should at least turn over. It will draw the cranking amps from the other battery and you can keep it running on alternator power. However, you can't charge a really drained battery with the alternator because the amperage output is too high. Try a trickle charge and if that doesn't work, it's new battery time.
- Scott
specbb6
Honda Civic (2006 - 2015)
Jun 24, 2012 03:07 PM
schueytenten
Oct 23, 2010 03:45 AM
99civicsiboosted
16
Jan 18, 2009 03:36 AM
LaOstha
17
Feb 21, 2005 02:15 PM
liljohnson
Jul 30, 2004 10:27 PM
