civic wont start!!!HELP I"M SCARED!!!
ok its been REALLY cold these past few days and today i tried to start my civic and the battery was dead. sooo i tried to jump it and when i would turn the key all it would to is Click clickclickcclickclick. sounds like my starter. does this happen when theres still not enough power?
why isnt it turning over?
i checked all the fluids and they are fine. antifreeze didnt freeze er anything.
HELP!!!!i'm very scared!!
Re: civic wont start!!!HELP I"M SCARED!!!
you're fine its most likely just a dead battery. The cold kills batteries. Make sure when you are jumping it that you clean teh corrosion off of the battery terminals so taht you get a good connection and also let it charge for a few minutes. If your battery is completely toast it may not even start by jumping it. you might just have to buy a new battery and take the hit.
when people think its the battery thats wrong it really isnt...its mostlikely your alternator.. but i could be wrong take the alternator to a autozona and make sure its working good.. good luck
The battery's job is to provide power for starting, and to absorb excess current draw while running accesories. The alternator's job is to recharge the battery when the engine is running as well as supply current for accesories. Don't assume a no crank condition means the alternator needs replacement. Make sure the battery is receiving a charge and can hold that charge first.
Resident Gearhead
Thank you Perfectionist. The alternator has nothing to do with the car not starting.
I remember when you used to post more.
I have had good luck leaving the "donating" car running for a while in effect charging the "recieving" cars battery enough for it to start.
As stated, it may need a new battery.
thanks guys yea all it was, was the battery was dead. i thought it friggin locked up on me from the cold (hasnt been driven in weeks)
but yea it was just a dead battery from the cold
i left it hooked up to my blazer for a few mins and it started right up then let it idle for about 20mins and is fine now.
thanks everyone, i'm a car guy but a total NOOB when it comes to hondas
but now i'm messin with a honda so i didnt know their starters did the same thing.
thanks again guys, i'm sure i will learn ALOT from you guys in the time coming.
-99civicsiboosted
yeah either get a new 1 or you could use the battery you got at the moment if it still holds a charge. start the car for even 5-10mins every second or third day just to keep that battery charged and you should be ok
yea the battery is fine i'm sure, its a brand new OPTIMA Yellow Top and those are supposed to be top-of-the-line batteries (better be for over 200 bucks lol)
plus its still under warranty.
it just went dead because of the REALLY cold temps we had, around negative 20 degrees for at least 5 days and like i said it hadnt been started in a couple weeks before it even got REALLY cold but it was still real cold for those couple weeks
well in that case you should be fine just start it up every now and again if its going to be sittin for days not being used. good look!
take it for a hour long cruise and let it charge back up or hook it up to a battery charger cuase if you dont give it a good charge it will just slowly die again.
speedracer33
05-02-2005 08:57 AM
