rpms drop when i press on throttle
ok so i have a first gen b16 with a 2000 si head in my 91 civic. for about 2 minutes after i start my car it acts up. when i push on the throttle my rpms drop almost to stal then they jump back up if i keep my foot on the throttle. and i also get a very strong smell of gas too. so i think my air to fuel ratio might be messed up but i dont know where. do any of you know where to start? thanks
ok so i dont know if this has anything to do with it or not but i get white smoke comming out of my exhaust. I know from my last car i had black smoke and i had a blown head gasket. I dont know if its my piston rings or my head gasket or what. Any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm92daintegra »</TD></TR><TR><TD CLASS="quote">is it white or blue , if its white is kewl , if its blue its oil , if its to much smoke then i think you have to much gas to it , what ecu you running </TD></TR></TABLE>
Actually, white smoke isnt kewl. It means you're leaking coolant into your combustion chamber, probably a bad head gasket. Check your oil and check it's consistency. If it's watery, then you're getting coolant into your combustion chamber and into your oil. Also, you can check your coolant resevior and see if it looks oily.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carma_626 »</TD></TR><TR><TD CLASS="quote">
Actually, white smoke isnt kewl. It means you're leaking coolant into your combustion chamber, probably a bad head gasket. Check your oil and check it's consistency. If it's watery, then you're getting coolant into your combustion chamber and into your oil. Also, you can check your coolant resevior and see if it looks oily. </TD></TR></TABLE>
damn i love this site
Once again.,,,, holly crap
White smoke with a "sweet smell" is burning coolant, could be a head gasket.
Grey/Blueish smoke is oil, could be valve seals or piston rings. Get a compression and leak down test.
Black smoke, or black residue on your bumper abover you exhaust tip is usually a sign of running very rich.
The air fuel gauge wont really tell you anything, they are more for show. I wideband will actaully tell you more. What ECu are you running? Any other mods to the car? O2 sensor hooked up?
ok so i took out my spark plugs and they looked good. one looked a little old. But all that they had on them was white resedue. Another thing i forgot to mention was that it hesitates in fifth going around 35 or 70. At 70 i will have to push the throttle down a bit to get it to speed up at all. dont know if that tells you guys anything.
oh yeah, also cleaned the spark plugs and white smoke still came out the back of my car when i pressed the throttle and the rpms still dropped and the smoke REAKED of gas.
lcsej1
26
Feb 17, 2009 09:30 PM
PRIMITIVEALLMOTOR
Engine Management and Tuning
Aug 23, 2008 01:44 PM
DamonBoost
Sep 13, 2001 05:03 PM
